跳转到主内容
Core Assembly Removal
你所需要的
  1. Core Assembly Removal, Unfasten the screws: 步骤 1 中的图像 1,1
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the four 3.9 mm-long Torx T3 screws.
    • Depending on the condition of your driver, a Torx T4 bit may fit better.
    • Don't try to detach the back cover yet. It is still connected to the watch assembly.
  2. Core Assembly Removal, Open the watch: 步骤 2 中的图像 1,2 Core Assembly Removal, Open the watch: 步骤 2 中的图像 2,2
    • Be careful not to strain the sensor flex cable during this procedure.
    • Carefully lift the back cover by the watch crown edge and swing it open to an upward position.
  3. Core Assembly Removal, Disconnect the sensor cable: 步骤 3 中的图像 1,2 Core Assembly Removal, Disconnect the sensor cable: 步骤 3 中的图像 2,2
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable.
  4. Core Assembly Removal, Remove the back cover: 步骤 4 中的图像 1,1
    • Remove the back cover.
  5. Core Assembly Removal, Core Assembly Removal: 步骤 5 中的图像 1,1
    • Remove the three 3.7 mm-long Phillips #00 screws.
  6. Core Assembly Removal: 步骤 6 中的图像 1,3 Core Assembly Removal: 步骤 6 中的图像 2,3 Core Assembly Removal: 步骤 6 中的图像 3,3
    • Insert the flat end of a spudger into the notch at the upper end of the white plastic frame.
    • Use your spudger as a lever and pry up the core assembly.
    • Don't try to remove the core assembly all the way yet—it is still connected to the watch body.
  7. Core Assembly Removal: 步骤 7 中的图像 1,2 Core Assembly Removal: 步骤 7 中的图像 2,2
    • Carefully lift the loose edge of the core assembly up and swing it to a 100-degree angle.
    • Be careful not to strain the display and sensor flex cables during this procedure.
  8. Core Assembly Removal: 步骤 8 中的图像 1,2 Core Assembly Removal: 步骤 8 中的图像 2,2
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the core assembly.
  9. Core Assembly Removal: 步骤 9 中的图像 1,2 Core Assembly Removal: 步骤 9 中的图像 2,2
    • Use the flat end of a spudger to pry up and disconnect the display flex cable from the core assembly.
  10. Core Assembly Removal: 步骤 10 中的图像 1,1
    • Remove the core assembly.
结论
Repair didn’t go as planned? Check out our Answers community for help.
4等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
247,560 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,758篇指南
1指南评论
Hello... in the event that you have submerged the smartwatch in salt water and it does not work, is there a solution?
luciano.alonso84@gmail.com - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 20
总计 1,474
