跳转到主内容
Compaq Evo N1000v Floppy Drive Replacement
你所需要的
  1. Compaq Evo N1000v Floppy Drive Replacement, LED Cover: 步骤 1 中的图像 1,1
    • Flip the laptop over with the rear panel facing forward.
  2. Compaq Evo N1000v Floppy Drive Replacement: 步骤 2 中的图像 1,1
    • Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
  3. Compaq Evo N1000v Floppy Drive Replacement: 步骤 3 中的图像 1,1
    • Flip the laptop back over with the front facing forward. Open the screen.
  4. Compaq Evo N1000v Floppy Drive Replacement: 步骤 4 中的图像 1,1
    • Locate the F1 and F2 keys near the top left corner of the keyboard.
  5. Compaq Evo N1000v Floppy Drive Replacement: 步骤 5 中的图像 1,1
    • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  6. Compaq Evo N1000v Floppy Drive Replacement: 步骤 6 中的图像 1,1
    • Locate the Scroll and Pause keys near the top right corner of the keyboard.
  7. Compaq Evo N1000v Floppy Drive Replacement: 步骤 7 中的图像 1,1
    • While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  8. Compaq Evo N1000v Floppy Drive Replacement: 步骤 8 中的图像 1,2 Compaq Evo N1000v Floppy Drive Replacement: 步骤 8 中的图像 2,2
    • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
  9. Compaq Evo N1000v Floppy Drive Replacement, Keyboard: 步骤 9 中的图像 1,1
    • Lift the back edge of the keyboard and pull towards the screen.
  10. Compaq Evo N1000v Floppy Drive Replacement: 步骤 10 中的图像 1,1
    • Pull the cable and lift up to release.
  11. Compaq Evo N1000v Floppy Drive Replacement: 步骤 11 中的图像 1,1
    • Remove the keyboard.
  12. Compaq Evo N1000v Floppy Drive Replacement, Palm Rest: 步骤 12 中的图像 1,1
    • Close the laptop and flip it so the rear panel is facing up.
  13. Compaq Evo N1000v Floppy Drive Replacement: 步骤 13 中的图像 1,1
    • Using the TR8 Torx screwdriver, remove the six screws from the back case.
  14. Compaq Evo N1000v Floppy Drive Replacement: 步骤 14 中的图像 1,1
    • Remove the battery.
    • Remove the screw from the metal support on the case edge with a Torx T8 screwdriver.
    • Flip the laptop over again so the top is facing up.
    • Open the laptop screen and face it towards you.
  15. Compaq Evo N1000v Floppy Drive Replacement: 步骤 15 中的图像 1,1
    • Lift the the palm rest up from the front edge of the laptop and swing it towards the screen.
    • Be gentle as it is connected by some cables.
  16. Compaq Evo N1000v Floppy Drive Replacement: 步骤 17 中的图像 1,1
    • Disconnect the second ribbon cable.
  17. Compaq Evo N1000v Floppy Drive Replacement: 步骤 18 中的图像 1,1
    • Remove the palm rest.
    • Locate and remove the three screws shown in picture.
  18. Compaq Evo N1000v Floppy Drive Replacement: 步骤 20 中的图像 1,1
    • Lift up and remove floppy drive from the palm rest.
结论
Alex Hernandez
于04/14/10注册
46 声望
创作了4篇指南
团队
Cal Poly, Team 29-74, Johann Spring 2010 Cal Poly, Team 29-74, Johann Spring 2010 的会员
CPSU-JOHANN-S10S29G74
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 3,341
