简介
以下情况可能需要你将手机置于Recovery模式:
- 你忘记了你的iPhone密码或你的iPhone已停用。
*你的iPhone开机时卡在了苹果logo,并且不显示进度条。
*你的iPhone陷入了开机死循环。
- 注意:如果你忘记了你的手机密码,你需要恢复设备。(出厂设置)
视频概述
要将你的iOS设备置于Recovery模式,请根据以下步骤操作,并且确保你有一台Mac或者已安装了iTunes的PC。
65等其他人完成本指南。
由衷感谢以下译者:
100%
整点没用的正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
7条评论
My power button is not working on an iphone 6, so I can't use these directions! Do you have a work around for this situation?
Thanks
Jeff
On iPhone 6, the power button is really only necessary to turn the device off. You can also accomplish this by disconnecting the battery. Which isn't ideal, but it's better than not being able to do it at all. After it's off, reconnect the battery, then hold down the home button and connect the lightning cable from the USB cable to your computer.
Alisha C -
Some repair tools can get the device into or out of Recovery Mode without pressing buttons physically. TunesKit iOS System Recovery has this feature for totally free, you can use this to put your iPhone into Recovery Mode without any limits.
My home button is not functioning, so even if I disconnect the battery and reconnect it, I will be at the same place. I had to use the digital home button to use the phone before it got disabled. It's that white circular digital button that can be used as an alternative when the physical home key is not functioning.
My phone just suddenly off by itself an iPhone 12 Pro Max please I don’t know what to do
