跳转到主内容
Comfort Zone CZ6C Power Cable Replacement
你所需要的
  1. Comfort Zone CZ6C Power Cable Replacement, Power Cable: 步骤 1 中的图像 1,3 Comfort Zone CZ6C Power Cable Replacement, Power Cable: 步骤 1 中的图像 2,3 Comfort Zone CZ6C Power Cable Replacement, Power Cable: 步骤 1 中的图像 3,3
    • Make sure to unplug the Comfort Zone CZ6C before cutting any wires.
    • Before attempting to replace your power cable, learn how to solder using the How To Solder and Desolder Corrections Guide.
    • Start with the fan on its back. Unscrew the back panel to expose the internal wiring.
  2. Comfort Zone CZ6C Power Cable Replacement: 步骤 2 中的图像 1,3 Comfort Zone CZ6C Power Cable Replacement: 步骤 2 中的图像 2,3 Comfort Zone CZ6C Power Cable Replacement: 步骤 2 中的图像 3,3
    • Unscrew the yellow cap that connects the black wire and the gray power cord wire. Then, unwind the tied wires and pull them apart.
  3. Comfort Zone CZ6C Power Cable Replacement: 步骤 3 中的图像 1,2 Comfort Zone CZ6C Power Cable Replacement: 步骤 3 中的图像 2,2
    • Remove the plastic cover on the switch by pulling it apart from the back panel.
  4. Comfort Zone CZ6C Power Cable Replacement: 步骤 4 中的图像 1,1
    • Use the soldering iron with caution. Don't touch the tip of the soldering iron to avoid the risk of injury.
    • This step can be made easier with the help of a partner to hold the wiring while you desolder the connection.
    • Disconnect the gray power wire from the switch by desoldering the connection.
  5. Comfort Zone CZ6C Power Cable Replacement: 步骤 5 中的图像 1,1
    • Strip the end of the gray power cord.
    • Then solder the end of the gray power cord to the switch.
结论
Nishanth Dara
于04/08/15注册
141 声望
撰写一个指南
团队
Cal Poly, Team 17-5, Forte Spring 2015 Cal Poly, Team 17-5, Forte Spring 2015 的会员
CPSU-FORTE-S15S17G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 23
总计 2,870
