当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Using a Phillips #1 screwdriver, remove the two 15mm screws on the motherboard.
Pull the entire motherboard towards the back of the system and carefully lift the entire motherboard.
Flip the motherboard over.
Using a soldering iron, carefully desolder the power switch from the motherboard.
Refer to this soldering technique guide for reference.
Wait for power switch to cool down.
Turn the motherboard over upright.
Carefully lift up the power switch to completely remove it from the motherboard.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
