跳转到主内容
加入维修社区 - 创建账户
ColecoVision Power Switch Replacement
你所需要的
  1. ColecoVision Power Switch Replacement, Power Switch: 步骤 1 中的图像 1,1
    • Flip the ColecoVision over with the pegs facing the ceiling.
    • Remove the eight 15mm screws holding the bottom of the ColecoVision in place using the Phillips #1 screwdriver.
  2. ColecoVision Power Switch Replacement: 步骤 2 中的图像 1,2 ColecoVision Power Switch Replacement: 步骤 2 中的图像 2,2
    • Carefully remove the bottom of the ColecoVision out of the top.
    • I would recommend running a metal spudger along the rim of the case to remove the bottom.
  3. ColecoVision Power Switch Replacement: 步骤 3 中的图像 1,1
    • Remove the two 15 mm screws holding the casing in place using the Phillips #1 screwdriver.
  4. ColecoVision Power Switch Replacement: 步骤 4 中的图像 1,2 ColecoVision Power Switch Replacement: 步骤 4 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the two 15mm screws on the motherboard.
    • Pull the entire motherboard towards the back of the system and carefully lift the entire motherboard.
  5. ColecoVision Power Switch Replacement: 步骤 5 中的图像 1,1
    • Flip the motherboard over.
    • Using a soldering iron, carefully desolder the power switch from the motherboard.
    • Refer to this soldering technique guide for reference.
  6. ColecoVision Power Switch Replacement: 步骤 6 中的图像 1,1
    • Wait for power switch to cool down.
    • Turn the motherboard over upright.
    • Carefully lift up the power switch to completely remove it from the motherboard.
结论
另外一个人完成了本指南。
Bobby
于10/17/18注册
380 声望
创作了2篇指南
团队
UW Tacoma, Team S1-G2, Rose Fall 2018 UW Tacoma, Team S1-G2, Rose Fall 2018 的会员
UWT-ROSE-F18S1G2
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 34
总计 2,155
