当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Flip the ColecoVision over with the pegs facing the ceiling.
Remove the eight 15mm screws holding the bottom of the ColecoVision in place using the Phillips #1 screwdriver.
Carefully remove the bottom of the ColecoVision out of the top.
I would recommend running a metal spudger along the rim of the case to remove the bottom.
Remove the two 15mm screws holding the casing in place using the Phillips #1 screwdriver.
Remove the casing and put it to the side.
Remove the two 15mm screws on the motherboard with a Phillips #1 screwdriver.
Pull the entire motherboard towards the back of the system and carefully lift the entire motherboard.
Flip the motherboard over and locate the two controller ports.
Using a soldering iron, desolder the controller ports.
Refer to this soldering technique guide for reference.
After waiting for controller ports to cool down, flip motherboard back over and carefully lift controller ports to remove.
取消:我没有完成这个指南。
与1其他贡献者
于10/17/18注册
380 声望
创作了2篇指南
徽章: 12
+ 9更多徽章
UWT-ROSE-F18S1G2
4 名成员
创作了12篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 26
总计 844
