跳转到主内容
ColecoVision Controller Port Replacement
你所需要的
  1. ColecoVision Controller Port Replacement, Controller Port: 步骤 1 中的图像 1,1
    • Flip the ColecoVision over with the pegs facing the ceiling.
    • Remove the eight 15mm screws holding the bottom of the ColecoVision in place using the Phillips #1 screwdriver.
  2. ColecoVision Controller Port Replacement: 步骤 2 中的图像 1,2 ColecoVision Controller Port Replacement: 步骤 2 中的图像 2,2
    • Carefully remove the bottom of the ColecoVision out of the top.
    • I would recommend running a metal spudger along the rim of the case to remove the bottom.
  3. ColecoVision Controller Port Replacement: 步骤 3 中的图像 1,2 ColecoVision Controller Port Replacement: 步骤 3 中的图像 2,2
    • Remove the two 15mm screws holding the casing in place using the Phillips #1 screwdriver.
    • Remove the casing and put it to the side.
  4. ColecoVision Controller Port Replacement: 步骤 4 中的图像 1,2 ColecoVision Controller Port Replacement: 步骤 4 中的图像 2,2
    • Remove the two 15mm screws on the motherboard with a Phillips #1 screwdriver.
    • Pull the entire motherboard towards the back of the system and carefully lift the entire motherboard.
  5. ColecoVision Controller Port Replacement: 步骤 5 中的图像 1,3 ColecoVision Controller Port Replacement: 步骤 5 中的图像 2,3 ColecoVision Controller Port Replacement: 步骤 5 中的图像 3,3
    • Flip the motherboard over and locate the two controller ports.
    • Using a soldering iron, desolder the controller ports.
    • Refer to this soldering technique guide for reference.
    • After waiting for controller ports to cool down, flip motherboard back over and carefully lift controller ports to remove.
结论
Bobby
于10/17/18注册
380 声望
创作了2篇指南
团队
UW Tacoma, Team S1-G2, Rose Fall 2018 UW Tacoma, Team S1-G2, Rose Fall 2018 的会员
UWT-ROSE-F18S1G2
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 17
总计 1,124
