简介
The purpose of this guide is to communicate steps on how to replace or repair the cartridge reader on a ColecoVision.
你所需要的
在这个步骤中使用的工具:Desoldering Pump$3.99
Desolder the sides of the cartridge reader using the soldering iron and desolder pump.
Patiently wait for the cartridge reader to cool down after being desoldered.
Carefully lift up the cartridge reader. A plastic spudger might be helpful in order to easily remove the cartridge reader.
2指南评论
If you’re removing the rivets holding the cartridge slot in place, it would be nice if you would mention what you did to secure the slot to the board after swapping the slot. I’m going to Lowe’s hardware and I will make a decent selection when I get there . I think I will be fine but it would nice to be able to have a specific size and length of screw to look for. Thanks!
No need to add the rivets. Soldering the connector in place is more than enough .
