跳转到主内容
加入维修社区 - 创建账户
Coby Kyros MID7024 Front Frame Replacement
你所需要的
  1. Coby Kyros MID7024  Front Frame Replacement, Back Cover: 步骤 1 中的图像 1,2 Coby Kyros MID7024  Front Frame Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Begin by ensuring that the device is powered off.
    • To replace the back cover of the device you must pry it open using the access points. One is located on the top of the device above the camera and the other is on the bottom left hand side.
    • Use the spudger to pry at the access points to open the device.
  2. Coby Kyros MID7024  Front Frame Replacement: 步骤 2 中的图像 1,3 Coby Kyros MID7024  Front Frame Replacement: 步骤 2 中的图像 2,3 Coby Kyros MID7024  Front Frame Replacement: 步骤 2 中的图像 3,3
    • Once the back cover begins to separate from the body of the device continue working the spudger around the perimeter of the device until the back cover is free.
    • You will hear some popping and cracking noises as you pry open the device. These sounds are the internal clips coming apart.
    • Once the back cover is free from the body of the device, open both sides like a book, placing them flat on the table as shown. Be sure to pay attention to the speaker wires that hold the two pieces together.
  3. Coby Kyros MID7024  Front Frame Replacement: 步骤 3 中的图像 1,3 Coby Kyros MID7024  Front Frame Replacement: 步骤 3 中的图像 2,3 Coby Kyros MID7024  Front Frame Replacement: 步骤 3 中的图像 3,3
    • This step is only necessary if you intend to repair or replace the back cover and/or speakers of the device.
    • In order to replace the back cover you must remove the speakers. Place the Spudger under the plastic frame of the speaker as shown. Pry up, popping the corners of the speakers out of of their bracket and lift the speaker out.
    • Be sure not to pull on the speaker's wires or body too hard as you may damage them.
  4. Coby Kyros MID7024  Front Frame Replacement, Battery: 步骤 4 中的图像 1,3 Coby Kyros MID7024  Front Frame Replacement, Battery: 步骤 4 中的图像 2,3 Coby Kyros MID7024  Front Frame Replacement, Battery: 步骤 4 中的图像 3,3
    • Locate the black tape connected to the battery and peel it back as indicated in the images.
  5. Coby Kyros MID7024  Front Frame Replacement: 步骤 5 中的图像 1,3 Coby Kyros MID7024  Front Frame Replacement: 步骤 5 中的图像 2,3 Coby Kyros MID7024  Front Frame Replacement: 步骤 5 中的图像 3,3
    • The battery is held to the device with two adhesive strips located on its underside.
    • After the battery is freed from the device, it will remain connected to the motherboard by two short wires.
    • Use the spudger tool to gently pry around both sides of the battery until it can be lifted from the device.
    • Roll the battery over (as shown in the image) so that its underside is now facing up. This will prevent damage to the motherboard.
  6. Coby Kyros MID7024  Front Frame Replacement: 步骤 6 中的图像 1,2 Coby Kyros MID7024  Front Frame Replacement: 步骤 6 中的图像 2,2
    • Use a soldering gun to remove the positive and negative wires connecting the battery to the motherboard.
    • Follow the guide on soldering to assist you in removing the battery.
  7. Coby Kyros MID7024  Front Frame Replacement, Motherboard: 步骤 7 中的图像 1,2 Coby Kyros MID7024  Front Frame Replacement, Motherboard: 步骤 7 中的图像 2,2
    • Locate the four 5mm screws holding the motherboard in place and remove them using the Phillips #0 Screwdriver.
    • Upon removal of the screws the motherboard should be able to lift up some. Do not remove it until all of the ribbon cables have been detached.
  8. Coby Kyros MID7024  Front Frame Replacement: 步骤 8 中的图像 1,3 Coby Kyros MID7024  Front Frame Replacement: 步骤 8 中的图像 2,3 Coby Kyros MID7024  Front Frame Replacement: 步骤 8 中的图像 3,3
    在这个步骤中使用的工具:
    • Locate the four ribbon cables shown in the yellow highlighted areas.
    • The digitizer is connected by a ZIF (zero insertion force) connector. The two black pieces on each end need to be pressed in simultaneously before the ribbon cable can be removed.
    • While pressing the black pieces, grasp the digitizer ribbon cable (widest one) with the tweezers and pull away from the connector as shown.
  9. Coby Kyros MID7024  Front Frame Replacement: 步骤 9 中的图像 1,3 Coby Kyros MID7024  Front Frame Replacement: 步骤 9 中的图像 2,3 Coby Kyros MID7024  Front Frame Replacement: 步骤 9 中的图像 3,3
    • Carefully remove the remaining ribbon cables using the tweezers. Make sure that all ribbon cables are detatched before attempting to remove the motherboard.
  10. Coby Kyros MID7024  Front Frame Replacement: 步骤 10 中的图像 1,2 Coby Kyros MID7024  Front Frame Replacement: 步骤 10 中的图像 2,2
    • Now gently remove the motherboard from the device.
  11. Coby Kyros MID7024  Front Frame Replacement, LCD Digitizer: 步骤 11 中的图像 1,2 Coby Kyros MID7024  Front Frame Replacement, LCD Digitizer: 步骤 11 中的图像 2,2
    • Be sure that the back cover, battery, and motherboard are all removed from the device as shown.
    • Be sure that all ribbon cables are disconnected and held out of the way.
    • Lay the device face down on the table so the metallic back of the digitizer is facing upwards.
    • Use a Phillips screwdriver to unscrew the four 5mm screws holding the digitizer to the frame.
  12. Coby Kyros MID7024  Front Frame Replacement: 步骤 12 中的图像 1,3 Coby Kyros MID7024  Front Frame Replacement: 步骤 12 中的图像 2,3 Coby Kyros MID7024  Front Frame Replacement: 步骤 12 中的图像 3,3
    • Use a plastic opening tool to wedge underneath the digitizer and pry up, lifting the digitizer out of the frame.
  13. Coby Kyros MID7024  Front Frame Replacement: 步骤 13 中的图像 1,2 Coby Kyros MID7024  Front Frame Replacement: 步骤 13 中的图像 2,2
    • The digitizer is now free from the front frame and ready to be repaired or replaced.
  14. Coby Kyros MID7024  Front Frame Replacement, Screen: 步骤 14 中的图像 1,3 Coby Kyros MID7024  Front Frame Replacement, Screen: 步骤 14 中的图像 2,3 Coby Kyros MID7024  Front Frame Replacement, Screen: 步骤 14 中的图像 3,3
    • Place front bezel with protective screen flat on the table with the button on your left and facing downward.
    • With your left hand find the corner of the protective screen closest to you. It is the corner with an extra area of removed plastic allowing a place large enough for a thumb to fit in. There will be a thin black strip of padded tape in that space.
    • Use your thumb to carefully push the protective screen away from the bezel. The adhesive will give way little by little. Do this all the way around the area of the screen until the screen is removed.
    • Do not apply too much force as you may damage the screen.
  15. Coby Kyros MID7024  Front Frame Replacement, Front Frame: 步骤 15 中的图像 1,2 Coby Kyros MID7024  Front Frame Replacement, Front Frame: 步骤 15 中的图像 2,2
    • The front bezel is now free from the device and is ready to be repaired or replaced.
结论
另外一个人完成了本指南。
Nicholas Bosco
于03/21/16注册
494 声望
创作了4篇指南
团队
Clemson, Team 6-3, Benson Spring 2016 Clemson, Team 6-3, Benson Spring 2016 的会员
CLEM-BENSON-S16S6G3
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 18
总计 288
