跳转到主内容
加入维修社区 - 创建账户
Coby KYROS MID7125 Screen Replacement
你所需要的
  1. Coby KYROS MID7125 Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Use iFixit plastic opening tool to make small opening in the side of the device, and continue opening back panel.
  2. Coby KYROS MID7125 Screen Replacement: 步骤 2 中的图像 1,3 Coby KYROS MID7125 Screen Replacement: 步骤 2 中的图像 2,3 Coby KYROS MID7125 Screen Replacement: 步骤 2 中的图像 3,3
    • There are 5 ribbon cables connected to the motherboard. Two of these cables are clipped on and one is soldered on. Remove the 4 ribbon cables you can clip off using the plastic spudger.
    • For large ribbon cable use plastic spudger or your fingers to release ribbon cable clip by pulling the black edges down and pulling ribbon cable out.
    • For ribbon cable on the left side, flip up black hinge to remove ribbon cable
    • Desolder fifth ribbon cable with soldering station.
    • If soldering is new for you, then follow this useful guide on soldering and desoldering connections.
  3. Coby KYROS MID7125 Screen Replacement: 步骤 3 中的图像 1,3 Coby KYROS MID7125 Screen Replacement: 步骤 3 中的图像 2,3 Coby KYROS MID7125 Screen Replacement: 步骤 3 中的图像 3,3
    • Desolder 2 speaker wires
    • Desolder Battery
    • Desolder antenna wire
    • Disconnect all wires you desoldered
  4. Coby KYROS MID7125 Screen Replacement: 步骤 4 中的图像 1,1
    • Desolder the microphone wire
    • Disconnect the wires you just desoldered.
  5. Coby KYROS MID7125 Screen Replacement: 步骤 5 中的图像 1,1
    • Remove 4 screws that connect the motherboard to the device.
  6. Coby KYROS MID7125 Screen Replacement: 步骤 6 中的图像 1,1
    • Take off motherboard by lifting off right hand side and pulling sideways.
  7. Coby KYROS MID7125 Screen Replacement: 步骤 7 中的图像 1,2 Coby KYROS MID7125 Screen Replacement: 步骤 7 中的图像 2,2
    • Remove 4 screws on corners of the digitizer and lift off.
  8. Coby KYROS MID7125 Screen Replacement: 步骤 8 中的图像 1,2 Coby KYROS MID7125 Screen Replacement: 步骤 8 中的图像 2,2
    • Now that the digitizer is disconnected from the screen you can replace the screen.
    • Place the screen face down in front of you facing downward and apply pressure with your thumbs around the outside of the glass to remove the screen.
    • Next, replace with your new screen and follow steps in reverse order to reassemble.
结论
Nicole Connelly
于10/20/16注册
1 声望
创作了3篇指南
团队
UMass Dartmouth, Team 5-2, Martin Fall 2016 UMass Dartmouth, Team 5-2, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S5G2
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 376
