跳转到主内容
Cleaning the Sensors of the Cassida Counterfeit Detector
你所需要的
  1. Cleaning the Sensors of the Cassida Counterfeit Detector, Cassida Counterfeit Detector: 步骤 1 中的图像 1,1
    • Remove the rubber legs.
  2. Cleaning the Sensors of the Cassida Counterfeit Detector: 步骤 2 中的图像 1,1
    • Using a Phillips #1 bit, remove the circled screws.
  3. Cleaning the Sensors of the Cassida Counterfeit Detector: 步骤 3 中的图像 1,1
    • Pry the top cover off, starting from the side with the switch, with a metal spudger.
  4. Cleaning the Sensors of the Cassida Counterfeit Detector: 步骤 4 中的图像 1,1
    • Pop the 4 tabs on the top of the machine up with a metal spudger and then remove the 2 side panels.
  5. Cleaning the Sensors of the Cassida Counterfeit Detector: 步骤 5 中的图像 1,1
    • Disconnect the wires circled and then remove the top section from the bottom section just by pulling the top section straight up and holding onto the bottom.
  6. Cleaning the Sensors of the Cassida Counterfeit Detector: 步骤 6 中的图像 1,1
    • All the parts disassembled.
  7. Cleaning the Sensors of the Cassida Counterfeit Detector, Cleaning the Sensors of the Cassida Counterfeit Detector: 步骤 7 中的图像 1,1
    • Remove the 4 screws that are circled with a Phillips #1 screwdriver.
    • Then lift up on the green motherboard.
  8. Cleaning the Sensors of the Cassida Counterfeit Detector: 步骤 8 中的图像 1,1
    • Once the motherboard is removed from the grey case, flip it over to expose the sensors.
  9. Cleaning the Sensors of the Cassida Counterfeit Detector: 步骤 9 中的图像 1,1
    • Clean the three sensors circled with isopropyl alcohol and a cue tip.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 15
总计 1,562
