跳转到主内容
Cassida Counterfeit Detector Disassembly
你所需要的
  1. Cassida Counterfeit Detector Disassembly, Cassida Counterfeit Detector Disassembly: 步骤 1 中的图像 1,1
    • Remove the rubber legs.
  2. Cassida Counterfeit Detector Disassembly: 步骤 2 中的图像 1,1
    • Using a Phillips #1 bit, remove the circled screws.
  3. Cassida Counterfeit Detector Disassembly: 步骤 3 中的图像 1,1
    • Pry the top cover off, starting from the side with the switch, with a metal spudger.
  4. Cassida Counterfeit Detector Disassembly: 步骤 4 中的图像 1,1
    • Pop the 4 tabs on the top of the machine up with a metal spudger and then remove the 2 side panels.
  5. Cassida Counterfeit Detector Disassembly: 步骤 5 中的图像 1,1
    • Disconnect the wires circled and then remove the top section from the bottom section just by pulling the top section straight up and holding onto the bottom.
  6. Cassida Counterfeit Detector Disassembly: 步骤 6 中的图像 1,1
    • All the parts disassembled.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 112
