跳转到主内容
Clarke Floor Sander 07012A 2012 Drum Expander Replacement
你所需要的
  1. 注意:步骤 1 源自标记为进行中的 指南
    Clarke Floor Sander 07012A 2012 Drum Expander Replacement, Disconnect all power cables: 步骤 1 中的图像 1,1
    • Before you begin your repair, disconnect all power cables to reduce the risk of short circuits and electric shock.
  2. Clarke Floor Sander 07012A 2012 Drum Expander Replacement, Remove the dust bag: 步骤 2 中的图像 1,2 Clarke Floor Sander 07012A 2012 Drum Expander Replacement, Remove the dust bag: 步骤 2 中的图像 2,2
    • Pull on the dust bag to remove it from the dust tube.
    • If the dust bag doesn't slide off easily, gently twist it back and forth while pulling to free it from the tube.
  3. Clarke Floor Sander 07012A 2012 Drum Expander Replacement, Remove the dust tube: 步骤 3 中的图像 1,1
    • Pull up on the dust tube to remove it from the sander.
  4. Clarke Floor Sander 07012A 2012 Drum Expander Replacement, Lower the sander and lift the front cover: 步骤 4 中的图像 1,3 Clarke Floor Sander 07012A 2012 Drum Expander Replacement, Lower the sander and lift the front cover: 步骤 4 中的图像 2,3 Clarke Floor Sander 07012A 2012 Drum Expander Replacement, Lower the sander and lift the front cover: 步骤 4 中的图像 3,3
    • Gently lower the sander onto its left side (the side with the belt guard).
    • Lift the front cover up and out of the way of the sanding drum.
  5. Clarke Floor Sander 07012A 2012 Drum Expander Replacement, Remove the sandpaper from the drum: 步骤 5 中的图像 1,3 Clarke Floor Sander 07012A 2012 Drum Expander Replacement, Remove the sandpaper from the drum: 步骤 5 中的图像 2,3 Clarke Floor Sander 07012A 2012 Drum Expander Replacement, Remove the sandpaper from the drum: 步骤 5 中的图像 3,3
    • Pull the sandpaper loop straight up and remove it from the drum.
  6. Clarke Floor Sander 07012A 2012 Drum Expander Replacement, Remove the Nyloc nut: 步骤 6 中的图像 1,2 Clarke Floor Sander 07012A 2012 Drum Expander Replacement, Remove the Nyloc nut: 步骤 6 中的图像 2,2
    • Remove the 3/4" nyloc nut from the drum end plate.
    • Nyloc nuts can be difficult to remove. If necessary, use an impact driver or another power tool for this step.
  7. Clarke Floor Sander 07012A 2012 Drum Expander Replacement, Remove the key washer: 步骤 7 中的图像 1,3 Clarke Floor Sander 07012A 2012 Drum Expander Replacement, Remove the key washer: 步骤 7 中的图像 2,3 Clarke Floor Sander 07012A 2012 Drum Expander Replacement, Remove the key washer: 步骤 7 中的图像 3,3
    • Use a flathead screwdriver or a prying tool to pry up the key washer and remove it from the drive shaft.
    • The key of the key washer may break off during removal. If so, replace the key washer with a new one during reassembly.
  8. Clarke Floor Sander 07012A 2012 Drum Expander Replacement, Attach the drum puller: 步骤 8 中的图像 1,2 Clarke Floor Sander 07012A 2012 Drum Expander Replacement, Attach the drum puller: 步骤 8 中的图像 2,2
    • Place the center screw of the drum puller onto the drive shaft of the sander and hook the puller jaws around the bottom end of the drum.
  9. Clarke Floor Sander 07012A 2012 Drum Expander Replacement, Remove the drum: 步骤 9 中的图像 1,3 Clarke Floor Sander 07012A 2012 Drum Expander Replacement, Remove the drum: 步骤 9 中的图像 2,3 Clarke Floor Sander 07012A 2012 Drum Expander Replacement, Remove the drum: 步骤 9 中的图像 3,3
    • Use a 15/16" socket and an impact driver or a socket wrench to drive the screw of the drum puller clockwise, lifting the drum off the drive shaft.
    • Once the drum has been lifted about halfway off the shaft, it should move freely and can be lifted the rest of the way by hand.
结论
9等其他人完成本指南。
Taylor Dixon
于06/26/18注册
67,237 声望
创作了94篇指南
一条评论
seoshingare5@gmail.com
Tube Expander
the best product more details for mantion in this link
https://www.shingare.com/tube-tools/tube...
seo shingare - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 120
总计 5,490
