跳转到主内容
Cineyo BT-03 Device Audio Jack Replacement
你所需要的
  1. Cineyo BT-03 Device Audio Jack Replacement, Cineyo BT-03 Device Disassembly: 步骤 1 中的图像 1,3 Cineyo BT-03 Device Audio Jack Replacement, Cineyo BT-03 Device Disassembly: 步骤 1 中的图像 2,3 Cineyo BT-03 Device Audio Jack Replacement, Cineyo BT-03 Device Disassembly: 步骤 1 中的图像 3,3
    • Remove the top (button side) rubber cover using your hands.
  2. Cineyo BT-03 Device Audio Jack Replacement: 步骤 2 中的图像 1,2 Cineyo BT-03 Device Audio Jack Replacement: 步骤 2 中的图像 2,2
    • Flip over the device and remove the bottom rubber cover using your hands.
  3. Cineyo BT-03 Device Audio Jack Replacement: 步骤 3 中的图像 1,3 Cineyo BT-03 Device Audio Jack Replacement: 步骤 3 中的图像 2,3 Cineyo BT-03 Device Audio Jack Replacement: 步骤 3 中的图像 3,3
    • Using your hands, pull off the plastic side cover (on the side with the audio jack) using the indented tab. The indented tab has been highlighted in the picture.
  4. Cineyo BT-03 Device Audio Jack Replacement: 步骤 4 中的图像 1,3 Cineyo BT-03 Device Audio Jack Replacement: 步骤 4 中的图像 2,3 Cineyo BT-03 Device Audio Jack Replacement: 步骤 4 中的图像 3,3
    • Detach the plastic speaker cover on both the front and back sides. Then slide the cover off of the device.
    • The cover should remain as one solid piece.
  5. Cineyo BT-03 Device Audio Jack Replacement: 步骤 5 中的图像 1,1
    • Remove the five 1 cm screws on the back side (opposite of the speakers) of the device using a Phillips #1 screwdriver.
  6. Cineyo BT-03 Device Audio Jack Replacement: 步骤 6 中的图像 1,1
    • Gently pull apart the two sections of the device.
  7. Cineyo BT-03 Device Audio Jack Replacement, Audio Jack: 步骤 7 中的图像 1,1
    • Disconnect all wires from the top of the circuit board.
  8. Cineyo BT-03 Device Audio Jack Replacement: 步骤 8 中的图像 1,1
    • Using a small Philips head screwdriver, remove the two 5 mm screws from the main circuit board.
  9. Cineyo BT-03 Device Audio Jack Replacement: 步骤 9 中的图像 1,1
    • Use the soldering iron to melt the two contact points that attach the wires to the rear side of the circuit board.
    • This will require soldering off the wires connecting the bottom of the circuit board to the device. iFixit's Soldering Guide is available to aid in soldering.
  10. Cineyo BT-03 Device Audio Jack Replacement: 步骤 10 中的图像 1,2 Cineyo BT-03 Device Audio Jack Replacement: 步骤 10 中的图像 2,2
    • Remove the circuit board from the device.
  11. Cineyo BT-03 Device Audio Jack Replacement: 步骤 11 中的图像 1,1
    • Using a soldering iron, remove the audio jack from the circuit board.
    • There are four contact points attaching the audio jack.
结论
另外一个人完成了本指南。
Rene Klopf
于01/30/17注册
463 声望
创作了4篇指南
团队
Baylor, Team 8-3, Whitney Spring 2017 Baylor, Team 8-3, Whitney Spring 2017 的会员
BU-WHITNEY-S17S8G3
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 167
