跳转到主内容
Chromo Noria Speaker Replacement
你所需要的
  1. Chromo Noria Speaker  Replacement, Back Panel: 步骤 1 中的图像 1,3 Chromo Noria Speaker  Replacement, Back Panel: 步骤 1 中的图像 2,3 Chromo Noria Speaker  Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Insert your Plastic Opening Tool into the crease between the front panel and back panel.
    • Slide the Opening Tool around the entire device. As you progress, you should see the device open.
  2. Chromo Noria Speaker  Replacement: 步骤 2 中的图像 1,1
    • Carefully turn the device over.
    • Lay the back panel aside so you can see the device's parts.
  3. Chromo Noria Speaker  Replacement, Speaker: 步骤 3 中的图像 1,1
    • Using your spudger tool, remove speaker from the backboard.
  4. Chromo Noria Speaker  Replacement: 步骤 4 中的图像 1,2 Chromo Noria Speaker  Replacement: 步骤 4 中的图像 2,2
    • Using the spudger tool, detach the speaker from the back of the screen.
  5. Chromo Noria Speaker  Replacement: 步骤 5 中的图像 1,1
    • Soldering irons get very hot! Be careful when handling one. If you'd like a tutorial on how to use one, click here.
    • Using a Soldering Iron, desolder both wires from the motherboard.
结论
Ryan Rho
于10/31/16注册
201 声望
创作了2篇指南
团队
Baylor, Team 5-6, Williams Fall 2016 Baylor, Team 5-6, Williams Fall 2016 的会员
BU-WILLIAMS-F16S5G6
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 135
