跳转到主内容
Chromo Noria Motherboard Replacement
你所需要的
  1. Chromo Noria Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,3 Chromo Noria Motherboard Replacement, Back Panel: 步骤 1 中的图像 2,3 Chromo Noria Motherboard Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Insert your Plastic Opening Tool into the crease between the front panel and back panel.
    • Slide the Opening Tool around the entire device. As you progress, you should see the device open.
  2. Chromo Noria Motherboard Replacement: 步骤 2 中的图像 1,1
    • Carefully turn the device over.
    • Lay the back panel aside so you can see the device's parts.
  3. Chromo Noria Motherboard Replacement, Battery: 步骤 3 中的图像 1,3 Chromo Noria Motherboard Replacement, Battery: 步骤 3 中的图像 2,3 Chromo Noria Motherboard Replacement, Battery: 步骤 3 中的图像 3,3
    • Place your finger at the end of the tape closest to the battery.
    • Peel the tape towards the flex cables to free the battery wires.
  4. Chromo Noria Motherboard Replacement: 步骤 4 中的图像 1,3 Chromo Noria Motherboard Replacement: 步骤 4 中的图像 2,3 Chromo Noria Motherboard Replacement: 步骤 4 中的图像 3,3
    • Using the spudger tool, place the tool along an edge of the battery.
    • Be careful not to bend or break the battery! Batteries contain hazards materials.
    • Move the spudger around the edges of the battery to detach it from the tablet.
  5. Chromo Noria Motherboard Replacement: 步骤 5 中的图像 1,1
    • Soldering irons get very hot! Be careful when handling one. If you'd like a tutorial on how to use one, click here.
    • Using a soldering iron, desolder both of the battery wires. The battery's wires are located to the left of the camera's flex cable.
    • Remove the battery.
  6. Chromo Noria Motherboard Replacement, Camera: 步骤 6 中的图像 1,2 Chromo Noria Motherboard Replacement, Camera: 步骤 6 中的图像 2,2
    • Carefully detach one side of the black tape from the board.
  7. Chromo Noria Motherboard Replacement: 步骤 7 中的图像 1,2 Chromo Noria Motherboard Replacement: 步骤 7 中的图像 2,2
    • Using a small plastic opening tool, flip the black connector up until it makes "tick" sound.
    • Now, the flexing cable is ready to be removed.
  8. Chromo Noria Motherboard Replacement: 步骤 8 中的图像 1,2 Chromo Noria Motherboard Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using a pair of tweezers, hold the flexing cable right below the black connector.
    • Gently pull the flexing cable out of the connector while balancing the other side of the device with another hand.
  9. Chromo Noria Motherboard Replacement, Speaker: 步骤 9 中的图像 1,1
    • Using your spudger tool, remove speaker from the backboard.
  10. Chromo Noria Motherboard Replacement: 步骤 10 中的图像 1,2 Chromo Noria Motherboard Replacement: 步骤 10 中的图像 2,2
    • Using the spudger tool, detach the speaker from the back of the screen.
  11. Chromo Noria Motherboard Replacement: 步骤 11 中的图像 1,1
    • Using a Soldering Iron, desolder both wires from the motherboard.
  12. Chromo Noria Motherboard Replacement, Motherboard: 步骤 12 中的图像 1,2 Chromo Noria Motherboard Replacement, Motherboard: 步骤 12 中的图像 2,2
    • Using a Phillips #00 Precision Screwdriver, remove the three 3mm screws by turning the screwdriver counter-clockwise.
  13. Chromo Noria Motherboard Replacement: 步骤 13 中的图像 1,1
    • Remove the three pieces of tap keeping the wires in place.
  14. Chromo Noria Motherboard Replacement: 步骤 14 中的图像 1,3 Chromo Noria Motherboard Replacement: 步骤 14 中的图像 2,3 Chromo Noria Motherboard Replacement: 步骤 14 中的图像 3,3
    • Place a spudger on the small black pins on either side of the flex cables.
    • Gently push the spudger towards the back of flex cables to unlock the flex cable.
    • Remove the flex cables from their insert.
  15. Chromo Noria Motherboard Replacement: 步骤 15 中的图像 1,1
    • Desolder the eight connections.
  16. Chromo Noria Motherboard Replacement: 步骤 16 中的图像 1,1
    • Lift the motherboard to remove.
结论
Nick Rohn
于10/30/16注册
475 声望
创作了3篇指南
团队
Baylor, Team 5-6, Williams Fall 2016 Baylor, Team 5-6, Williams Fall 2016 的会员
BU-WILLIAMS-F16S5G6
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 8
总计 226
