跳转到主内容
Casio LK-170 Speaker Replacement
你所需要的
  1. Casio LK-170 Speaker Replacement, Speaker: 步骤 1 中的图像 1,3 Casio LK-170 Speaker Replacement, Speaker: 步骤 1 中的图像 2,3 Casio LK-170 Speaker Replacement, Speaker: 步骤 1 中的图像 3,3
    • Locate the seven 11mm screws on the back of the keyboard in order to remove the speaker from the front of the keyboard.
    • There are 7 screws that need to be removed in total to replace one speaker. Use a JIS-1 screwdriver to remove these screws: 2 on the back panel, and 4 on the side of the keyboard.
    • Three of these seven screws are slightly hidden and may be hard to find.
  2. Casio LK-170 Speaker Replacement: 步骤 2 中的图像 1,2 Casio LK-170 Speaker Replacement: 步骤 2 中的图像 2,2
    • Gently remove the speaker and its compartment from the front of the keyboard.
  3. Casio LK-170 Speaker Replacement: 步骤 3 中的图像 1,1
    • Remove the four 11 mm screws with JIS-1 screwdriver on the four corners of the silver square on the back of the speaker.
  4. Casio LK-170 Speaker Replacement: 步骤 4 中的图像 1,2 Casio LK-170 Speaker Replacement: 步骤 4 中的图像 2,2
    • A soldering iron is needed to remove the wires connected to the speaker in order to fully replace it. For soldering help, take a look at the Soldering and Desoldering Connections guide.
    • Desolder the metal that attaches the blue and white wires to the speaker.
    • Remove the speaker.
结论
Samantha Baker
于01/24/17注册
425 声望
创作了4篇指南
团队
Cal Poly, Team 13-2, Banghart Winter 2017 Cal Poly, Team 13-2, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S13G2
3 名成员
创作了5篇指南
一条评论
How much is a replacement speaker and where do I get one for the BRAND new keyboard U just bought that doesnt work through the left speaker (LK 265)
Heather Quigley - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 702
