简介
If your Casio G-Shock GA110-1B Watch isn’t working/turning on as before, then probably the battery has died and will require a replacement.
With a battery, it helps the watch to function. But as time flies by, the battery will eventually die out, leaving the watch not working like before.
And with this guide I create, I will show you how to replace a battery on a Casio G-Shock GA110-1B Watch. There is no need to go and get somebody to replace the battery for you when you can do it at home. Also, no need to throw away your watch when the battery dies.
你所需要的
视频概述
Remove the four screws from the back of the watch using the Phillips #0 Screwdriver
For optimal performance, after completing this guide, calibrate your newly installed battery.
3等其他人完成本指南。
3指南评论
syncing the hands with the digital clock, should you just turn the hands?
found a guide online on how to set g-shock hands, just hold down reverse and forward button at the same time for a few seconds, and too long to explain, search it up or experiment with it, it's quite easy
