跳转到主内容
Casio G-Shock GA110-1B Battery Replacement
你所需要的
视频概述
  1. Casio G-Shock GA110-1B Battery Replacement, A Guide on Battery Replacement: 步骤 1 中的图像 1,3 Casio G-Shock GA110-1B Battery Replacement, A Guide on Battery Replacement: 步骤 1 中的图像 2,3 Casio G-Shock GA110-1B Battery Replacement, A Guide on Battery Replacement: 步骤 1 中的图像 3,3
    • Remove the four screws from the back of the watch using the Phillips #0 Screwdriver
  2. Casio G-Shock GA110-1B Battery Replacement: 步骤 2 中的图像 1,3 Casio G-Shock GA110-1B Battery Replacement: 步骤 2 中的图像 2,3 Casio G-Shock GA110-1B Battery Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to remove the metal cover.
    • Make sure not to lose the rubber circle underneath the metal cover because it's part of the watch.
  3. Casio G-Shock GA110-1B Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the white cover carefully.
    • Using the pair of tweezers, unhook where the battery is held onto.
    • You are going to need to pull the hook will a bit of force. As seen in the video.
    • Be careful!! Do not pull it too hard with the tweezers. You don't want to damage the hook where the battery is placed.
  4. Casio G-Shock GA110-1B Battery Replacement: 步骤 5 中的图像 1,3 Casio G-Shock GA110-1B Battery Replacement: 步骤 5 中的图像 2,3 Casio G-Shock GA110-1B Battery Replacement: 步骤 5 中的图像 3,3
    • Use a pair of tweezers or your fingers to remove the battery from its place.
    • Remove the new battery from its packaging.
  5. Casio G-Shock GA110-1B Battery Replacement: 步骤 6 中的图像 1,2 Casio G-Shock GA110-1B Battery Replacement: 步骤 6 中的图像 2,2
    • Place the new battery where it belongs with your fingers. Hook it back onto the device to secure it in place.
    • Reattach the white cover onto the device.
  6. Casio G-Shock GA110-1B Battery Replacement: 步骤 7 中的图像 1,3 Casio G-Shock GA110-1B Battery Replacement: 步骤 7 中的图像 2,3 Casio G-Shock GA110-1B Battery Replacement: 步骤 7 中的图像 3,3
    • Don't forget that the rubber goes 1st inside the watch before placing the metal cover.
    • Make sure that the metal cover is aligned with the watch and not upside down.
    • Put back the metal cover and screw in back the four screws using the Phillips #0 screwdriver.
    • After screwing in the four screws, flip the watch over. Push the button on the bottom left and the watch should turn on!
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
2等其他人完成本指南。
Hector Mejia
于10/05/21注册
361 声望
撰写一个指南
团队
CSU Los Angeles, Team 11-3, Grodsky Fall 2021 CSU Los Angeles, Team 11-3, Grodsky Fall 2021 的会员
CSULA-GRODSKY-F21S11G3
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 84
过去 30 天: 338
总计 4,549
