跳转到主内容
Casio CTK-501 Battery Connection Replacement
你所需要的
  1. Casio CTK-501 Battery Connection Replacement, Bottom Panel: 步骤 1 中的图像 1,2 Casio CTK-501 Battery Connection Replacement, Bottom Panel: 步骤 1 中的图像 2,2
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 Battery Connection Replacement: 步骤 2 中的图像 1,1
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 Battery Connection Replacement: 步骤 3 中的图像 1,2 Casio CTK-501 Battery Connection Replacement: 步骤 3 中的图像 2,2
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 Battery Connection Replacement, Battery Connection: 步骤 4 中的图像 1,1
    • Plug in the soldering iron.
    • Set the soldering iron somewhere safe, where it can't catch anything on fire.
    • Unscrew the top green circuit board with black and red wires running through it.
  5. Casio CTK-501 Battery Connection Replacement: 步骤 5 中的图像 1,1
    • Set the circuit board somewhere flat so it is safe to solder.
  6. Casio CTK-501 Battery Connection Replacement: 步骤 6 中的图像 1,1
    • Heat up the solder covering the end of the wires connected to the circuit board.
    • Once the solder melts, remove the wires from the circuit board.
  7. Casio CTK-501 Battery Connection Replacement: 步骤 7 中的图像 1,1
    • Melt new solder with your soldering iron.
    • Then apply it over the tip of the wire resting on the circuit board.
  8. Casio CTK-501 Battery Connection Replacement: 步骤 8 中的图像 1,1
    • Once the wires are firmly attached, screw the circuit board back into the keyboard.
结论
3等其他人完成本指南。
Jimmy Winne
于10/04/12注册
578 声望
创作了6篇指南
团队
Cal Poly, Team 9-16, Amido Fall 2012 Cal Poly, Team 9-16, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G16
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 22
总计 5,219
