跳转到主内容
Canon Selphy CP910 Printer Body Replacement
你所需要的
  1. Canon Selphy CP910 Printer Body Replacement, Disassembling Canon Selphy CP910 Body: 步骤 1 中的图像 1,2 Canon Selphy CP910 Printer Body Replacement, Disassembling Canon Selphy CP910 Body: 步骤 1 中的图像 2,2
    • Turn the printer over.
    • Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
    • Keep track of these screws because you will need them to reassemble the printer.
  2. Canon Selphy CP910 Printer Body Replacement: 步骤 2 中的图像 1,3 Canon Selphy CP910 Printer Body Replacement: 步骤 2 中的图像 2,3 Canon Selphy CP910 Printer Body Replacement: 步骤 2 中的图像 3,3
    • Loosen up the four 10 mm corner screws.
    • A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws.
  3. Canon Selphy CP910 Printer Body Replacement: 步骤 3 中的图像 1,3 Canon Selphy CP910 Printer Body Replacement: 步骤 3 中的图像 2,3 Canon Selphy CP910 Printer Body Replacement: 步骤 3 中的图像 3,3
    • Turn the device around and remove the "open" lid.
    • This lid needs to be removed in order to take the printer apart.
    • Gently bend the lid and remove it from its hinges.
  4. Canon Selphy CP910 Printer Body Replacement: 步骤 4 中的图像 1,3 Canon Selphy CP910 Printer Body Replacement: 步骤 4 中的图像 2,3 Canon Selphy CP910 Printer Body Replacement: 步骤 4 中的图像 3,3
    • Turn the device back over and lift the top panel up.
    • Disconnect the ribbon cables leading to the LCD screen.
    • Pull the top panel off.
  5. Canon Selphy CP910 Printer Body Replacement, Printer Body: 步骤 5 中的图像 1,2 Canon Selphy CP910 Printer Body Replacement, Printer Body: 步骤 5 中的图像 2,2
    • Use the PH1 screw driver to remove the three screws on the motherboard.
  6. Canon Selphy CP910 Printer Body Replacement: 步骤 6 中的图像 1,2 Canon Selphy CP910 Printer Body Replacement: 步骤 6 中的图像 2,2
    • Remove the printer.
    • This will prevent the printer from falling out during repair.
  7. Canon Selphy CP910 Printer Body Replacement: 步骤 7 中的图像 1,3 Canon Selphy CP910 Printer Body Replacement: 步骤 7 中的图像 2,3 Canon Selphy CP910 Printer Body Replacement: 步骤 7 中的图像 3,3
    • Remove the output connections.
    • Be careful! Do not pull too hard because the wires might rip.
    • Output connections are located on the corners of the motherboard.
  8. Canon Selphy CP910 Printer Body Replacement: 步骤 8 中的图像 1,2 Canon Selphy CP910 Printer Body Replacement: 步骤 8 中的图像 2,2
    • The motherboard is attached to three more ribbon wires.
    • Detach these wires.
    • Be careful not to pull too hard.
  9. Canon Selphy CP910 Printer Body Replacement: 步骤 9 中的图像 1,2 Canon Selphy CP910 Printer Body Replacement: 步骤 9 中的图像 2,2
    • Separate the motherboard from the main hard drive.
  10. Canon Selphy CP910 Printer Body Replacement: 步骤 10 中的图像 1,3 Canon Selphy CP910 Printer Body Replacement: 步骤 10 中的图像 2,3 Canon Selphy CP910 Printer Body Replacement: 步骤 10 中的图像 3,3
    • Remove the main hard drive from the printer body.
  11. Canon Selphy CP910 Printer Body Replacement: 步骤 11 中的图像 1,2 Canon Selphy CP910 Printer Body Replacement: 步骤 11 中的图像 2,2
    • Gently remove the fan from the body.
    • The fan is glued to the case. When you install it in the new body, use hot glue to secure it in place.
  12. Canon Selphy CP910 Printer Body Replacement: 步骤 12 中的图像 1,2 Canon Selphy CP910 Printer Body Replacement: 步骤 12 中的图像 2,2
    • The empty case will look like this once all the parts are removed.
结论
2等其他人完成本指南。
团队
UW Tacoma, Team 1-6, Rose Winter 2016 UW Tacoma, Team 1-6, Rose Winter 2016 的会员
UWT-ROSE-W16S1G6
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 56
总计 4,236
