跳转到主内容
Canon Selphy CP910 LCD Screen Replacement
你所需要的
  1. Canon Selphy CP910 LCD Screen Replacement, Body: 步骤 1 中的图像 1,2 Canon Selphy CP910 LCD Screen Replacement, Body: 步骤 1 中的图像 2,2
    • Turn the printer over.
    • Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
    • Keep track of these screws because you will need them to reassemble the printer.
  2. Canon Selphy CP910 LCD Screen Replacement: 步骤 2 中的图像 1,3 Canon Selphy CP910 LCD Screen Replacement: 步骤 2 中的图像 2,3 Canon Selphy CP910 LCD Screen Replacement: 步骤 2 中的图像 3,3
    • Loosen up the four 10 mm corner screws.
    • A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws.
  3. Canon Selphy CP910 LCD Screen Replacement: 步骤 3 中的图像 1,3 Canon Selphy CP910 LCD Screen Replacement: 步骤 3 中的图像 2,3 Canon Selphy CP910 LCD Screen Replacement: 步骤 3 中的图像 3,3
    • Turn the device around and remove the "open" lid.
    • This lid needs to be removed in order to take the printer apart.
    • Gently bend the lid and remove it from its hinges.
  4. Canon Selphy CP910 LCD Screen Replacement: 步骤 4 中的图像 1,3 Canon Selphy CP910 LCD Screen Replacement: 步骤 4 中的图像 2,3 Canon Selphy CP910 LCD Screen Replacement: 步骤 4 中的图像 3,3
    • Turn the device back over and lift the top panel up.
    • Disconnect the ribbon cables leading to the LCD screen.
    • Pull the top panel off.
  5. Canon Selphy CP910 LCD Screen Replacement, LCD Screen: 步骤 5 中的图像 1,3 Canon Selphy CP910 LCD Screen Replacement, LCD Screen: 步骤 5 中的图像 2,3 Canon Selphy CP910 LCD Screen Replacement, LCD Screen: 步骤 5 中的图像 3,3
    • Once you detach the top, turn the device around.
    • Use the PH0 screw bit to remove the five [size] screws.
  6. Canon Selphy CP910 LCD Screen Replacement: 步骤 6 中的图像 1,3 Canon Selphy CP910 LCD Screen Replacement: 步骤 6 中的图像 2,3 Canon Selphy CP910 LCD Screen Replacement: 步骤 6 中的图像 3,3
    • Push out the LCD screen from the main case.
    • The screen should slide out freely.
  7. Canon Selphy CP910 LCD Screen Replacement: 步骤 7 中的图像 1,3 Canon Selphy CP910 LCD Screen Replacement: 步骤 7 中的图像 2,3 Canon Selphy CP910 LCD Screen Replacement: 步骤 7 中的图像 3,3
    • Pull out the rod connecting the LCD screen to the frame.
    • Insert the new screen.
结论
团队
UW Tacoma, Team 1-6, Rose Winter 2016 UW Tacoma, Team 1-6, Rose Winter 2016 的会员
UWT-ROSE-W16S1G6
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 1,487
