当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Flip the battery cover open.
Using your fingers, slide the battery out of the camera.
This was not the original battery that came the camera, so yours may look different.
Using the Phillips #00 screwdriver, remove the two 3.1mm screws from the bottom of the camera.
Keep track of all the screws that are being taken out from the outer case.
The display screen of the camera should be facing towards you.
Ensure that the screen is facing you, and then rotate it till you see the screws on the side of the camera.
Use the Phillips #00 screwdriver to remove the two 3.1 mm screws.
With the screen still facing you, rotate the camera 180 degrees.
The side with the charging port should now be facing up.
Use the Philips #00 screwdriver to pry open the charging port cover.
Once you pry open the charging port cover, rotate the cover so that you have access to the screw underneath. Which is seen in the next image.
Remove both 3.1 mm screws using the Phillips #00 screwdriver.
The image still shows the screw from step 3 in place.
Turn the camera so the bottom is once again facing up.
With the battery door still open, use a spudger to remove the cover from the front of the camera.
Carefully go around all of the edges until the cover is released.
Just like Step 4-6 , carefully use the Spudger to remove the back cover.
Go along all the borders of the back cover so that it releases from the camera safely.
Be careful not to break the tabs.
Make sure the battery is removed.
Cut the wires half way between the microphone and body of camera.
Leave 25mm of wire on the speaker when cutting the wire
Remove the 3.1mm screw holding speaker to the housing.
Remove the two clips and the metal cover will be released
When you remove the metal cover the spring will shoot out.
Take note of the spring and its orientation, it will need to be re-installed later
Image of the spring
Using tweezers, grab the wires to pull the speaker from the plastic housing.
Use force as the speaker is glued to the housing.
Test the heat of the soldering iron by touching it to the tip of a paperclip.
If the tip of the paperclip melts, the iron should be ready.
If you have never used a soldering iron before, please consult the tutorial in the description of this guide, or watch the following video: How To Solder Or Soldering Techniques .
Solder the red wire to the right terminal, and the black wire to the left terminal.
Do not apply force to the speaker wires during this step. If the wires break, you will need to re-solder them.
Lift up the corner of the metal cover and slide the spring in so it rests around the screw hole.
After the spring is around the screw hole post, replace the screw so that the cover stays in place.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
