跳转到主内容
Canon Powershot A610 Speaker Replacement
你所需要的
  1. Canon Powershot A610 Speaker Replacement, Speaker: 步骤 1 中的图像 1,3 Canon Powershot A610 Speaker Replacement, Speaker: 步骤 1 中的图像 2,3 Canon Powershot A610 Speaker Replacement, Speaker: 步骤 1 中的图像 3,3
    • Remove the three screws attaching the side panel using a Phillips #00 screwdriver.
    • Remove the side paneling from the camera.
    • Remove the two remaining screws attached to the frame of the camera.
  2. Canon Powershot A610 Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the two screws on the bottom panel of the camera.
  3. Canon Powershot A610 Speaker Replacement: 步骤 3 中的图像 1,1
    • Open the battery cover.
    • Remove the four screws inside.
    • One screw is located on the top side of the bottom cover. The remaining three screws are located at the bottom of the battery compartment.
    • Close the battery cover.
  4. Canon Powershot A610 Speaker Replacement: 步骤 4 中的图像 1,2 Canon Powershot A610 Speaker Replacement: 步骤 4 中的图像 2,2
    • Open the "DIGITAL AV OUT" door on the camera.
    • Remove the three screws.
    • Remove the door from the camera.
  5. Canon Powershot A610 Speaker Replacement: 步骤 5 中的图像 1,1
    • Gripping the sides of the top cover, gently pull apart the top cover from the camera.
    • The top cover does not completely detach.
  6. Canon Powershot A610 Speaker Replacement: 步骤 6 中的图像 1,2 Canon Powershot A610 Speaker Replacement: 步骤 6 中的图像 2,2
    • Gently pull apart the front cover from the camera.
    • This may require some force. Be careful not to break the plastic.
  7. Canon Powershot A610 Speaker Replacement: 步骤 7 中的图像 1,2 Canon Powershot A610 Speaker Replacement: 步骤 7 中的图像 2,2
    • Using an opening tool, push the black attachment away from the white connection piece to detach the connector ribbon.
  8. Canon Powershot A610 Speaker Replacement: 步骤 8 中的图像 1,1
    • Remove the 3 mm screw holding the metal frame.
  9. Canon Powershot A610 Speaker Replacement: 步骤 9 中的图像 1,2 Canon Powershot A610 Speaker Replacement: 步骤 9 中的图像 2,2
    • Use an unfolded paper clip to push the speaker from the top of the casing out towards the bottom.
    • Use a bit of force as the speaker is glued into the top casing.
    • There is a soft fabric speaker cover separating the speaker from the casing. Make sure not to remove it from its position in the housing.
  10. Canon Powershot A610 Speaker Replacement: 步骤 10 中的图像 1,1
    • Desolder the speaker at the two solder points and reattach the new speaker.
结论
Matthew Ramirez
于01/20/11注册
625 声望
创作了5篇指南
团队
Cal Poly, Team 11-26, Maness Winter 2011 Cal Poly, Team 11-26, Maness Winter 2011 的会员
CPSU-MANESS-W11S11G26
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 2,957
