跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot SD450 Lens Assembly Replacement
你所需要的
    1. Canon PowerShot SD450 Lens Assembly Replacement, Casing: 步骤 1 中的图像 1,1
      • Remove the battery and SD Card from their slots. Leaving these in could cause the battery to ground and ruin the electronics.
      • Unscrew the six screws on the casing. Two are on the bottom as pictured; two more are on each side of the camera.
      询问修复机器人
      添加评论
    2. Canon PowerShot SD450 Lens Assembly Replacement: 步骤 2 中的图像 1,1
      • Pull the lanyard mount off of the camera using a spudger or your fingers.
      询问修复机器人
      添加评论
    3. Canon PowerShot SD450 Lens Assembly Replacement: 步骤 3 中的图像 1,2 Canon PowerShot SD450 Lens Assembly Replacement: 步骤 3 中的图像 2,2
      • Find the line that separates the casing into its two halves. Hold each half separately, and gently pull apart.
      • Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
      询问修复机器人
      添加评论
    4. Canon PowerShot SD450 Lens Assembly Replacement: 步骤 4 中的图像 1,1
      • Take hold of the inside of the camera, and gently pull away from the back casing.
      询问修复机器人
      添加评论
    5. Canon PowerShot SD450 Lens Assembly Replacement: 步骤 5 中的图像 1,1
      • Remove the square, clear, rubber protector from the front of the logic board. This is not necessary to remove, but can easily fall off and get lost during later steps.
      询问修复机器人
      添加评论
    6. Canon PowerShot SD450 Lens Assembly Replacement: 步骤 6 中的图像 1,1
      • When you reassemble the camera, make sure the switch on the casing matches the position of the switch on the camera internals.
      • The black viewfinder padding can easily fall off the casing. Make sure you don't lose it when moving around parts.
      询问修复机器人
      添加评论
    1. Canon PowerShot SD450 Lens Assembly Replacement, Motherboard: 步骤 7 中的图像 1,1
      • Remove the LCD cable by gently prying the hinge open with a spudger or your finger. The cable should easily slide out.
      询问修复机器人
      添加评论
    2. Canon PowerShot SD450 Lens Assembly Replacement: 步骤 8 中的图像 1,1
      • Lift up the metallic-colored clip with the spudger to remove the shutter panel.
      询问修复机器人
      添加评论
    3. Canon PowerShot SD450 Lens Assembly Replacement: 步骤 9 中的图像 1,1
      • Remove the shutter panel with the spudger, now that the clip is released.
      询问修复机器人
      添加评论
    4. Canon PowerShot SD450 Lens Assembly Replacement: 步骤 10 中的图像 1,1
      • Use the spudger or your finger to release the orange ribbon from the logic board.
      询问修复机器人
      添加评论
    5. Canon PowerShot SD450 Lens Assembly Replacement: 步骤 11 中的图像 1,1
      • Pull the ribbon out of the socket using the spudger or your finger.
      • Disconnect the two other ribbons from the logic board in the same fashion.
      询问修复机器人
      添加评论
    6. Canon PowerShot SD450 Lens Assembly Replacement: 步骤 12 中的图像 1,1
      • Lift up the large green flap by using the spudger to pry up top right yellow edge.
      询问修复机器人
      添加评论
    7. Canon PowerShot SD450 Lens Assembly Replacement: 步骤 13 中的图像 1,1
      • Pull the flap back with the spudger so that the logic board is exposed.
      询问修复机器人
      添加评论
    8. Canon PowerShot SD450 Lens Assembly Replacement: 步骤 14 中的图像 1,1
      • Use the screwdriver to remove the three screws on the logic board. Take note that the bottom right screw is shorter than the other two.
      询问修复机器人
      添加评论
    9. Canon PowerShot SD450 Lens Assembly Replacement: 步骤 15 中的图像 1,1
      • Use the spudger to carefully remove the logic board from behind.
      询问修复机器人
      添加评论
    10. Canon PowerShot SD450 Lens Assembly Replacement: 步骤 16 中的图像 1,1
      • Remove the detached logic board from the camera.
      询问修复机器人
      添加评论
    1. Canon PowerShot SD450 Lens Assembly Replacement, Flash Bulb: 步骤 17 中的图像 1,1
      • Remove the side screw holding the flash bulb.
      询问修复机器人
      添加评论
    2. Canon PowerShot SD450 Lens Assembly Replacement: 步骤 18 中的图像 1,1
      • Remove the orange ribbon from below the lens.
      询问修复机器人
      添加评论
    3. Canon PowerShot SD450 Lens Assembly Replacement: 步骤 19 中的图像 1,1
      在这个步骤中使用的工具:
      • Grasp the plug that yellow and black wires are attached to, and gently remove. Tweezers are very helpful here.
      询问修复机器人
      添加评论
    4. Canon PowerShot SD450 Lens Assembly Replacement: 步骤 20 中的图像 1,3 Canon PowerShot SD450 Lens Assembly Replacement: 步骤 20 中的图像 2,3 Canon PowerShot SD450 Lens Assembly Replacement: 步骤 20 中的图像 3,3
      • Note that there is a capacitor in the flash bulb assembly, under the small circuit board. Do not touch the two metal terminals, as the capacitor may discharge. Damage and personal injury may result.
      • Use the spudger to carefully lift the flash bulb out.
      询问修复机器人
      添加评论
    1. Canon PowerShot SD450 Lens Assembly Replacement, Lens Assembly: 步骤 21 中的图像 1,1
      • Remove the screw at the upper right-hand corner of the LCD screen
      询问修复机器人
      添加评论
    2. Canon PowerShot SD450 Lens Assembly Replacement: 步骤 22 中的图像 1,1
      • Remove the function buttons by sliding the spudger underneath the black rubber and lifting up.
      询问修复机器人
      添加评论
    3. Canon PowerShot SD450 Lens Assembly Replacement: 步骤 23 中的图像 1,1
      • Lift up the LCD screen WITHOUT removing it completely. The screen is still connected to the camera via a backlight ribbon underneath.
      询问修复机器人
      添加评论
    4. Canon PowerShot SD450 Lens Assembly Replacement: 步骤 24 中的图像 1,1
      • Remove the last screw holding the tripod mount to the case. The LCD ribbon threads under the mount, so upon reinstallation, the ribbon will need to be threaded through before the mount is reattached. Take note of the tripod mount orientation.
      询问修复机器人
      添加评论
    5. Canon PowerShot SD450 Lens Assembly Replacement: 步骤 25 中的图像 1,1
      • Pull the back light ribbon from it's socket to remove the LCD completely. There is a little hole you can stick the spudger into to help release the ribbon.
      询问修复机器人
      添加评论
    6. Canon PowerShot SD450 Lens Assembly Replacement: 步骤 26 中的图像 1,2 Canon PowerShot SD450 Lens Assembly Replacement: 步骤 26 中的图像 2,2
      • Lift up the black tape from the right corner to expose the LED
      • Push the out from the top of the camera, pulling away from the direction of the lens.
      询问修复机器人
      添加评论
    7. Canon PowerShot SD450 Lens Assembly Replacement: 步骤 27 中的图像 1,1
      • Remove the three screws which secure the lens assembly to the main chassis.
      询问修复机器人
      添加评论
    8. Canon PowerShot SD450 Lens Assembly Replacement: 步骤 28 中的图像 1,2 Canon PowerShot SD450 Lens Assembly Replacement: 步骤 28 中的图像 2,2
      • Remove the lens carefully from the chassis. You're done!
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
团队
Cal Poly, Team 25-85, Amido Spring 2010 Cal Poly, Team 25-85, Amido Spring 2010 的会员
CPSU-AMIDO-S10S25G85
4 名成员
创作了10篇指南
1指南评论
This helped me fix my Canon IXUS 60. The lens was completely broken so I ordered a new lens module from ebay. Thanks to this guide I was able to fix it!
bijsterz - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 70
总计 9,161
