跳转到主内容
Canon PowerShot SD1400 IS USB Port Replacement
你所需要的
  1. Canon PowerShot SD1400 IS USB Port Replacement, USB Port: 步骤 1 中的图像 1,3 Canon PowerShot SD1400 IS USB Port Replacement, USB Port: 步骤 1 中的图像 2,3 Canon PowerShot SD1400 IS USB Port Replacement, USB Port: 步骤 1 中的图像 3,3
    • Remove the four 2mm Phillips #00 screws on both sides of the camera.
  2. Canon PowerShot SD1400 IS USB Port Replacement: 步骤 2 中的图像 1,1
    • Remove the single 4mm Phillips #00 screw from the bottom.
  3. Canon PowerShot SD1400 IS USB Port Replacement: 步骤 3 中的图像 1,1
    • Remove the front face panel off of the camera.
  4. Canon PowerShot SD1400 IS USB Port Replacement: 步骤 4 中的图像 1,1
    • Remove the rear panel of the camera.
    • The user interface panel, side and bottom panel of the camera may fall down by itself while you are taking the rear panel of the camera.
  5. Canon PowerShot SD1400 IS USB Port Replacement: 步骤 5 中的图像 1,1
    • Remove the 3mm Phillips #000 screw from the top of the camera.
  6. Canon PowerShot SD1400 IS USB Port Replacement: 步骤 6 中的图像 1,1
    • Pry the golden ribbon cable from the motherboard with a plastic opening tool.
    • A screw will be visible underneath the golden ribbon after prying it.
  7. Canon PowerShot SD1400 IS USB Port Replacement: 步骤 7 中的图像 1,1
    • Remove the 3mm Phillips #000 screw from the motherboard.
  8. Canon PowerShot SD1400 IS USB Port Replacement: 步骤 8 中的图像 1,1
    • Use a plastic opening tool to flip up the retaining flap on the ribbon cable ZIF socket.
  9. Canon PowerShot SD1400 IS USB Port Replacement: 步骤 9 中的图像 1,2 Canon PowerShot SD1400 IS USB Port Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • Unplug the small chip from the face of the camera using a pair of tweezers.
  10. Canon PowerShot SD1400 IS USB Port Replacement: 步骤 10 中的图像 1,1
    • Remove the 3mm Phillips #000 screw from the rear face of the camera.
  11. Canon PowerShot SD1400 IS USB Port Replacement: 步骤 11 中的图像 1,1
    • Remove the top panel from the camera.
  12. Canon PowerShot SD1400 IS USB Port Replacement: 步骤 12 中的图像 1,1
    • Pry the golden ribbon cable attached to the USB port using a plastic opening tool.
  13. Canon PowerShot SD1400 IS USB Port Replacement: 步骤 13 中的图像 1,1
    • Remove the 3mm Phillips #000 screw located at the top right of the USB port.
  14. Canon PowerShot SD1400 IS USB Port Replacement: 步骤 14 中的图像 1,2 Canon PowerShot SD1400 IS USB Port Replacement: 步骤 14 中的图像 2,2
    • Remove the USB port.
结论
另外一个人完成了本指南。
Faris Rezwan
于05/21/18注册
457 声望
创作了2篇指南
团队
IUPUI, Team S1-G2, Harley Spring 2018 IUPUI, Team S1-G2, Harley Spring 2018 的会员
IUPUI-HARLEY-S18S1G2
7 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 321
