当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
There are six 3mm exterior screws that will need to be removed in order to remove the exterior frame.
Two screws near the tripod mount on the underside of the camera.
Two screws on the camera left hand side (the face with nothing but screws on it).
Two screws on the camera right hand side, by the wrist strap attachment.
Remove the screws using the screwdriver.
这个步骤还没有翻译 帮忙翻译一下
Carefully pull apart the two parts of the exterior frame.
Use the spudger to pry apart the two frame components.
Once disconnected, the two parts of the frame can be easily separated by using your fingers.
The rear frame should be removed first.
There should be an O-ring on the front face of the camera. Ensure to keep the O-ring with the front part of the frame.
这个步骤还没有翻译 帮忙翻译一下
At the back of the camera, there are four 2.5mm screws that will need to be removed in order for the screen to pull off.
One at the top of the camera that is connected to a bracket that secures the screen.
Two on the back of the camera,near the speaker.
One hidden behind the bracket.
这个步骤还没有翻译 帮忙翻译一下
Gently lift the screen and pull it apart from the camera, taking care to unslot the screen brackets from the tabs on the bottom and left side of the camera.
Do not pull too hard on the screen as there is still another delicate cable running from the screen to the rear board of the camera.
Gently pull the wide ribbon (shown in an earlier step) cable from the front of the camera to the back using tweezers.
这个步骤还没有翻译 帮忙翻译一下
The screen is now connected only by a small cable that runs to the rear board of the camera. Using tweezers, slowly pull the cable out of the connector.
For best results, grip the cable as close to the connector as possible.
The screen should now be separate from the camera body. Be careful not to harm the connectors on the lens so it will reconnect successfully.
这个步骤还没有翻译 帮忙翻译一下
There are two 3.25mm screws that hold the tripod mount in the camera.
The first screw is located on the back of the camera above the tripod mount.
The second screw is located on the lens side of the camera above the tripod mount.
Remove the second screw using the Phillips 00 Screwdriver.
这个步骤还没有翻译 帮忙翻译一下
Using the spudger, gently push up the board from the pins underneath it.
Follow the board up and around the camera, gently unseating the board and cables.
The speaker will still be connected to the board via two small power wires. Use the tweezers to pull and unplug the power connector from the main rear accessory board.
另外一个人完成了本指南。
