跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot A590 IS Memory Card Replacement
  1. Canon PowerShot A590 IS Memory Card Replacement, Open the Battery Hatch: 步骤 1 中的图像 1,1
    • Be gentle with the hatch, it is fragile.
    • *See battery replacement guide for help opening the hatch.
    询问修复机器人
  2. Canon PowerShot A590 IS Memory Card Replacement, Locate Memory Card: 步骤 2 中的图像 1,1
    • The memory card slot is shown here in the red rectangle.
    询问修复机器人
  3. Canon PowerShot A590 IS Memory Card Replacement, Remove Memory Card: 步骤 3 中的图像 1,1
    • To eject your memory card, simply press it into the camera gently, and it will spring out.
    • After it has been released from the camera, just pull it out.
    询问修复机器人
  4. Canon PowerShot A590 IS Memory Card Replacement, Replace Memory Card: 步骤 4 中的图像 1,1
    • To replace the memory card, make sure it is oriented with the label facing towards the front of the camera, with the contacts going in first, facing the back of the camera.
    • Push the card into the slot gently until you hear a 'click'. It will then be locked into place in the camera.
    询问修复机器人
结论
4等其他人完成本指南。
Zach
于10/11/10注册
284 声望
创作了6篇指南
团队
Cal Poly, Team 9-19, Regan Fall 2010 Cal Poly, Team 9-19, Regan Fall 2010 的会员
CPSU-REGAN-F10S9G19
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 80
总计 6,109
