跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot A590 IS Flash Assembly Replacement
你所需要的
  1. Canon PowerShot A590 IS Flash Assembly Replacement, Batteries: 步骤 1 中的图像 1,2 Canon PowerShot A590 IS Flash Assembly Replacement, Batteries: 步骤 1 中的图像 2,2
    • The battery hatch is on the bottom of the camera.
    • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • While the switch is pushed forward, pull the cover away from the camera.
  2. Canon PowerShot A590 IS Flash Assembly Replacement: 步骤 2 中的图像 1,1
    • This camera requires AA batteries.
    • To remove batteries, simply allow them to fall out of the camera.
    • Use a fingernail to lift the clock battery out of the camera.
    询问修复机器人
  3. Canon PowerShot A590 IS Flash Assembly Replacement: 步骤 3 中的图像 1,1
    • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
    询问修复机器人
  4. Canon PowerShot A590 IS Flash Assembly Replacement, Back Cover: 步骤 4 中的图像 1,1
    • Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
    询问修复机器人
  5. Canon PowerShot A590 IS Flash Assembly Replacement: 步骤 5 中的图像 1,1
    • Remove the two screws located on the other side of the camera using a Phillips #00 screwdriver.
    询问修复机器人
  6. Canon PowerShot A590 IS Flash Assembly Replacement: 步骤 6 中的图像 1,1
    • Remove the three screws located at the bottom of the camera using a Phillips #00 screwdriver.
    询问修复机器人
  7. Canon PowerShot A590 IS Flash Assembly Replacement: 步骤 7 中的图像 1,1
    • Open the battery cover.
    • Using the iFixit opening tool, push up gently around all edges of the camera.
  8. Canon PowerShot A590 IS Flash Assembly Replacement, Remove Lens Cover: 步骤 8 中的图像 1,1
    • Press and hold down the button shown in the blue circle.
    • While pressing the button, rotate the lens cover in a counter-clockwise direction to remove it.
    询问修复机器人
  9. Canon PowerShot A590 IS Flash Assembly Replacement, Remove Front Cover: 步骤 9 中的图像 1,2 Canon PowerShot A590 IS Flash Assembly Replacement, Remove Front Cover: 步骤 9 中的图像 2,2
    • Remove the front cover of the camera.
    • This may require a bit of force.
    询问修复机器人
  10. Canon PowerShot A590 IS Flash Assembly Replacement, Remove Plastic Covering: 步骤 10 中的图像 1,1
    • Remove the one (1) screw from the top of the camera, on the left side of the flash (looking from the front) using a Phillips #00 screwdriver.
    • Lift the black plastic covering off the circuit board.
    询问修复机器人
  11. Canon PowerShot A590 IS Flash Assembly Replacement, Remove Green Circuit Board: 步骤 11 中的图像 1,1
    • Remove the green circuit board from the top. Looking from the front of the camera, first lift the left side up above the black peg. The board should then slide out to the left.
    • The clear flash lens may fall out. Do not worry this will not affect the camera and can easily be placed back in its spot.
    询问修复机器人
  12. Canon PowerShot A590 IS Flash Assembly Replacement, Unsolder Circuit Board Cables: 步骤 12 中的图像 1,1
    • Unsolder the cables under the circuit board.
    询问修复机器人
  13. Canon PowerShot A590 IS Flash Assembly Replacement: 步骤 13 中的图像 1,1
    • The flash logic board can now be removed from the camera and replaced.
    询问修复机器人
结论
3等其他人完成本指南。
Zach
于10/11/10注册
284 声望
创作了6篇指南
团队
Cal Poly, Team 9-19, Regan Fall 2010 Cal Poly, Team 9-19, Regan Fall 2010 的会员
CPSU-REGAN-F10S9G19
4 名成员
创作了14篇指南
2指南评论
Zach, can you show how to replace the Ring Release Button? The release button appears to be fixed to the front cover once it is removed. Can we purchase a replacement release button?
Jae Ennis - 回复 分享
If it is the flash element that needs to be replace, I presume I will see it when I’m there.
Is this correct ?
effitech_structure@yahoo.com
Jean-François Rondeau - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 55
总计 16,449
