简介
Locate and remove the clock battery from the camera.
你所需要的
To access the clock battery, find the clock battery cover, shown here in the red square.
When accessing the clock battery, use a fingernail or similar small instrument to gently pull the tab out.
Now that you have the tab and battery removed, use a fingernail or other small tool to remove the battery from the tab.
This battery is a CR1220 type watch battery.
13等其他人完成本指南。
9指南评论
thanks its very useful forme
thank you, very useful for my old camera :)
agungsp2000 - 回复 分享
Perfect! I never even knew I had this battery in there. Couldn't figure out why the date and time wouldn't stay set every time I shut it off. And then I found the answer here.
Thank you very much for the post!
sherlock261 - 回复 分享
I'm a senior citizen and am not very good with modern technology. Been going crazy trying to set my clock in my digital camera. I didn't want to buy a new one because I have had this one for years (Power Shot A590) and didn't want to have to learn to use a newer one. Finally got smart enough to do a google search for an answer. Will get a new battery tomorrow and solve my problem. Thanks for the help!...the information age is good for something after all.
Pat Solomon - 回复 分享
Wow this is a great site. I got the answer I needed right away. The instructions were clear, simple and correct. Thank you.
You are bookmarked.
