简介
You will remove screws from the bottom and sides of the camera in order to remove the cameras back cover.
The battery hatch is on the bottom of the camera.
While the switch is pushed forward, pull the cover away from the camera.
This camera requires AA batteries. To remove batteries, simply allow them to fall out of the camera.
The clock battery cover is shown here in the purple circle. Use a fingernail to lift the battery out of the camera.
When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
Remove the screw located under the rubber flap on the left side of the camera using a magnetic screwdriver.
Remove the two screws located on the other side of the camera using a magnetic screwdriver
Remove the three screws located at the bottom of the camera using a magnetic screwdriver.
Open the battery cover.
Using the iPod tool, push up gently around all edges of the camera.
7等其他人完成本指南。
