跳转到主内容
Canon PowerShot A2500 Retractable Lens Replacement
你所需要的
  1. Canon PowerShot A2500 Retractable Lens Replacement, Body Casing and Faceplate: 步骤 1 中的图像 1,2 Canon PowerShot A2500 Retractable Lens Replacement, Body Casing and Faceplate: 步骤 1 中的图像 2,2
    • Remove the knot holding the wrist lanyard onto the camera
  2. Canon PowerShot A2500 Retractable Lens Replacement: 步骤 2 中的图像 1,1
    • Open the latch at the bottom corner of the device to reveal the battery and SD card housing.
    • There is an orange latch holding the battery in place which must be pushed back in order to free the battery.
    • Once the battery is removed push the SD card and this will activate a spring ejecting the card from the camera.
  3. Canon PowerShot A2500 Retractable Lens Replacement: 步骤 3 中的图像 1,3 Canon PowerShot A2500 Retractable Lens Replacement: 步骤 3 中的图像 2,3 Canon PowerShot A2500 Retractable Lens Replacement: 步骤 3 中的图像 3,3
    • Remove the 6 Phillips #00 exterior screws from the camera. Two are located on the bottom and two are located on either side as shown. Notice that one of the screws is under the AV Out Digital flap on the side. All exterior screws should be 2.4mm in length
  4. Canon PowerShot A2500 Retractable Lens Replacement: 步骤 4 中的图像 1,3 Canon PowerShot A2500 Retractable Lens Replacement: 步骤 4 中的图像 2,3 Canon PowerShot A2500 Retractable Lens Replacement: 步骤 4 中的图像 3,3
    • Pry apart the camera casing using the plastic opening tool tool provided. Once the casing has begun to separate pull the two sides apart with your hands.
    • Be careful not to bend the plastic casing to much, as it will crack.
  5. Canon PowerShot A2500 Retractable Lens Replacement, Buttons: 步骤 5 中的图像 1,1
    • Remove the single philips #00 screw on the button pad which are 2.2mm long. This screw is circled in red in the guide image.
    • Next, remove the two 2.4mm long screws located in between the LCD screen and the touch pad. These screws will require a Phillips #00 screwdriver.
  6. Canon PowerShot A2500 Retractable Lens Replacement: 步骤 6 中的图像 1,2 Canon PowerShot A2500 Retractable Lens Replacement: 步骤 6 中的图像 2,2
    • Pull the two clips off located near the power button
    • The clips are easily broken, use care while disconnecting these clips.
  7. Canon PowerShot A2500 Retractable Lens Replacement: 步骤 7 中的图像 1,3 Canon PowerShot A2500 Retractable Lens Replacement: 步骤 7 中的图像 2,3 Canon PowerShot A2500 Retractable Lens Replacement: 步骤 7 中的图像 3,3
    • Remove the circuit ribbon connecting the flash to the camera in order to proceed to the next instruction.
    • Carefully pull out the circuit ribbon from the camera which should be the last piece holding the button pad onto the camera.
  8. Canon PowerShot A2500 Retractable Lens Replacement, Internal LCD Frame: 步骤 8 中的图像 1,1
    • Pop the LCD display out of its frame using the plastic opening tool in order to get to the screws under the display. Use the plastic opening tool to complete this step
  9. Canon PowerShot A2500 Retractable Lens Replacement: 步骤 9 中的图像 1,3 Canon PowerShot A2500 Retractable Lens Replacement: 步骤 9 中的图像 2,3 Canon PowerShot A2500 Retractable Lens Replacement: 步骤 9 中的图像 3,3
    • Remove the four following phillips #00 screws from the metal frame
    • There should be two screws top right, one bottom left, and one on bottom of the frame
    • The screw dimensions should follow: Top right should be 2.3mm and 3.6mm long. Bottom left should be 3.6mm and the bottom of the frame should be 1.6mm
  10. Canon PowerShot A2500 Retractable Lens Replacement, Retractable Lens: 步骤 10 中的图像 1,1
    • Lift the tabs at the end of both ribbons
    • Disconnect each ribbon from the circuit board
结论
另外一个人完成了本指南。
Lynden Mills
于03/24/15注册
229 声望
撰写一个指南
团队
UMass Dartmouth, Team 3-4, Duarte Spring 2015 UMass Dartmouth, Team 3-4, Duarte Spring 2015 的会员
UMASSD-DUARTE-S15S3G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 55
总计 2,118
