简介
If the scanner on your Canon PIXMA MP620B is not scanning your document and the scanner light did not turn on, it has possibly burnt out and needs replacement.
However, before using this guide, check to see if your driver is up to date. If your printer does not have the right software, the light will not turn on because the printer will not be able to read your commands. You can find driver and software updates here.
你所需要的
You will have to pry off the glass cover lid. There are no screws that you have to worry about. Just insert a spudger into the crack between the glass lid and black base as shown.
After lifting the glass cover up, the light assembly will come free because it was only held in place by the glass top.
Now that the scanner light assembly is free. Lift it out of the scanner bed and unplug the large white wire that attaches it to the rest of the printer.
5等其他人完成本指南。
