Carefully use the plastic opening tool to pry the casing apart along the seam.
Follow the seam with the plastic tool until the back is ready to remove.
Potential for device damage: Make sure you use the grounding strip to remove the chance of discharging static electricity into the internal components.
Remove the five ribbon connectors along the bottom of the assembly using either needle nose tweezers or a plastic opening tool to flip the small flaps to the "up" position.
Use a nylon spudger to pull each ribbon connector out of its connection using the hole in the center of the ribbon.
Disconnect the small plastic connectors on the top left corner of the motherboard by gripping the small plastic portion of the wire and gently pulling out of the connector.
Disconnect the three ribbon connectors along the top.
Don't detach the connectors underneath or the ribbon connectors with the foam block, as these will be removed later.
