跳转到主内容
Canon EOS Rebel T1i Front Screen Replacement
你所需要的
  1. Canon EOS Rebel T1i Front Screen Replacement, Front Screen: 步骤 1 中的图像 1,1
    • Clean the broken or cracked screen as best as possible.
    • Place the suction cup on the damaged screen.
  2. Canon EOS Rebel T1i Front Screen Replacement: 步骤 2 中的图像 1,2 Canon EOS Rebel T1i Front Screen Replacement: 步骤 2 中的图像 2,2
    • While holding the suction cup flat against the camera screen, suction the two together by pinching the orange handles to meet at the center.
  3. Canon EOS Rebel T1i Front Screen Replacement: 步骤 3 中的图像 1,3 Canon EOS Rebel T1i Front Screen Replacement: 步骤 3 中的图像 2,3 Canon EOS Rebel T1i Front Screen Replacement: 步骤 3 中的图像 3,3
    • Grab the handle of the suction cup and gently lift it up at an angle, as demonstrated in the picture.
    • Remove the plastic screen from the camera.
    • Release the broken screen by pulling down the lever of the suction cup.
结论
5等其他人完成本指南。
Michael Peck
于04/14/14注册
167 声望
撰写一个指南
团队
Cal Poly, Team 3-41, Maness Spring 2014 Cal Poly, Team 3-41, Maness Spring 2014 的会员
CPSU-MANESS-S14S3G41
4 名成员
创作了10篇指南
一条评论
Be sure to measure the size of your screen before buying the suction cups. I got the heavy-duty ones and then found that they were too big for my Rebel T1i screen.
cmorris - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 48
总计 5,662
