跳转到主内容
Canon EOS 6D Rear Body Panel Replacement
你所需要的
  1. Canon EOS 6D Rear Body Panel Replacement, Rear Body Panel: 步骤 1 中的图像 1,1
    • Remove the viewfinder cover by pinching the sides and sliding it upward.
  2. Canon EOS 6D Rear Body Panel Replacement: 步骤 2 中的图像 1,1
    • Open the battery door on the bottom of the camera.
    • Use your thumb to slide the small black tab on the inside of the battery door up and pull the door off the camera.
  3. Canon EOS 6D Rear Body Panel Replacement: 步骤 3 中的图像 1,1
    • Slide your fingernail or the flat end of the spudger underneath the rubber covering and gently peel it off all sides of the camera.
    Presume includes same procedure for the right hand side of the camera which is now shown as derubberised
    laylow - 回复
    It is unnecessary to completely remove the rubber from the right side of the back panel - in the next step where you remove two screws, simply lift the top right corner for access.
    rakurai - 回复
  4. Canon EOS 6D Rear Body Panel Replacement: 步骤 4 中的图像 1,1
    • Open the covers to the HDMI/AV/MIC ports on the side of the camera by gently pulling outward on the bottom of the covers.
    • Rotate the covers to the side so that you can see the connection ports inside.
    • Remove the following screws:
    • Two silver 5mm Phillips #00
    • One black 6mm Phillips #00
    Phillips#0 seemed to be a more secure fit.
    John Hood - 回复
  5. Canon EOS 6D Rear Body Panel Replacement: 步骤 5 中的图像 1,1
    • Remove the cover to the HDMI/AV/MIC ports by gently lifting the tab on the bottom edge of the camera.
  6. Canon EOS 6D Rear Body Panel Replacement: 步骤 6 中的图像 1,1
    • Rotate your camera so the bottom side is facing you.
    • One 6mm Phillips #00
    • Two 3mm Phillips #00
    Correction:
    2x 3mm Phillips #00
    1x 6mm Phillips #00 in battery compartment
    Joey Fresco - 回复
    Figure circle is not correct. Joey Fresco is right.
    Tomonori OTA - 回复
    the 6mm phillips #00 is under the grip.  The other 2 are 3mm.
    Jay Wang - 回复
  7. Canon EOS 6D Rear Body Panel Replacement: 步骤 7 中的图像 1,1
    • Rotate your camera so the back is facing you.
    • Three silver 5mm Phillips #00
    • Two black 6mm Phillips #00
    • One black 4mm Phillips #00
  8. Canon EOS 6D Rear Body Panel Replacement: 步骤 8 中的图像 1,2 Canon EOS 6D Rear Body Panel Replacement: 步骤 8 中的图像 2,2
    • A black ribbon wire connects the rear panel to the inside of the camera. Breaking this wire would make your rear screen and buttons non-functional.
    • Carefully use your fingers to tilt the back panel downward to about a 90 degree angle.
    • Use the flat end of the spudger to gently pry off the ribbon wire from the inside of the camera.
    The ribbon cable is connected to the camera via a plug (the gold colored PCB has a male plug on the other side of the PCB). This plug is at the end of the spudger. You need to pull that PCB boar/plug straight up from the camera (perpendicular to the camera)
    Jim R - 回复
    There is a metal piece protruding from the back panel into the main body, down near the battery door. DO NOT simply bend the back panel down 90 degrees! Gently pull the entire back (including the lower right corner near the battery door) straight away from the camera about 1cm, and then lower the back panel 90 degrees.
    rakurai - 回复
结论
12等其他人完成本指南。
Justin Thomas
于04/22/14注册
2,188 声望
创作了6篇指南
团队
Cal Poly, Team 11-48, Amido Spring 2014 Cal Poly, Team 11-48, Amido Spring 2014 的会员
CPSU-AMIDO-S14S11G48
4 名成员
创作了18篇指南
2条评论
Thanks alot, very helpful
busulwa paddy - 回复
Thanks alot, very helpful fixed an issue
busulwa paddy - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 47
总计 10,152
