跳转到主内容
Canon EOS 30 Grip Replacement
你所需要的
  1. Canon EOS 30 Grip Replacement, Front Panel: 步骤 1 中的图像 1,1
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
  2. Canon EOS 30 Grip Replacement: 步骤 2 中的图像 1,1
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  3. Canon EOS 30 Grip Replacement: 步骤 3 中的图像 1,1
    • Remove the 4.8 mm black screw on the left side of the camera.
  4. Canon EOS 30 Grip Replacement: 步骤 4 中的图像 1,1
    • Remove the front panel by lifting it away from the camera's body.
    I need a video tutorial
    Abdullah dicky S - 回复
  5. Canon EOS 30 Grip Replacement, Top Panel: 步骤 5 中的图像 1,1
    • Slide the outer eyepiece upward to remove it.
  6. Canon EOS 30 Grip Replacement: 步骤 6 中的图像 1,1
    • Remove the two 4.75 mm black screws located on the top of the camera.
  7. Canon EOS 30 Grip Replacement: 步骤 7 中的图像 1,1
    • Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
  8. Canon EOS 30 Grip Replacement: 步骤 8 中的图像 1,2 Canon EOS 30 Grip Replacement: 步骤 8 中的图像 2,2
    • Slowly separate the top panel from the camera by pushing it upward.
    • Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
  9. Canon EOS 30 Grip Replacement, Side Panel With Remote Control Socket: 步骤 9 中的图像 1,1
    • Remove two 6.5 mm black screws from the panel.
  10. Canon EOS 30 Grip Replacement: 步骤 10 中的图像 1,1
    • Remove the plastic remote control socket cap by pulling it straight out.
  11. Canon EOS 30 Grip Replacement: 步骤 11 中的图像 1,2 Canon EOS 30 Grip Replacement: 步骤 11 中的图像 2,2
    • Slide the panel toward the bottom of the camera to remove.
  12. Canon EOS 30 Grip Replacement: 步骤 12 中的图像 1,1
    • Remove the single 4.8 silver screw from the control socket.
  13. Canon EOS 30 Grip Replacement: 步骤 13 中的图像 1,2 Canon EOS 30 Grip Replacement: 步骤 13 中的图像 2,2
    • The control socket is now secure by three wires.
    • Desolder connections to replace the remote control socket.
  14. Canon EOS 30 Grip Replacement, Grip: 步骤 14 中的图像 1,1
    • Remove the two 5.5 mm screws from front of camera.
  15. Canon EOS 30 Grip Replacement: 步骤 15 中的图像 1,1
    • Remove grip panel.
结论
Jackie
于04/17/11注册
236 声望
创作了3篇指南
团队
Cal Poly, Team 8-8, Regan Spring 2011 Cal Poly, Team 8-8, Regan Spring 2011 的会员
CPSU-REGAN-S11S8G8
5 名成员
创作了22篇指南
一条评论
Didn't you forget the step to remove the bottom plate?
Sino Lino - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 3,774
