跳转到主内容
Canon EOS 30 Battery Door Replacement
你所需要的
  1. Canon EOS 30 Battery Door Replacement, Front Panel: 步骤 1 中的图像 1,1
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
  2. Canon EOS 30 Battery Door Replacement: 步骤 2 中的图像 1,1
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  3. Canon EOS 30 Battery Door Replacement: 步骤 3 中的图像 1,1
    • Remove the 4.8 mm black screw on the left side of the camera.
  4. Canon EOS 30 Battery Door Replacement: 步骤 4 中的图像 1,1
    • Remove the front panel by lifting it away from the camera's body.
  5. Canon EOS 30 Battery Door Replacement, Bottom Panel: 步骤 5 中的图像 1,1
    • Remove seven 4.25 mm black screws on the bottom panel.
  6. Canon EOS 30 Battery Door Replacement: 步骤 6 中的图像 1,1
    • Remove the bottom panel.
  7. Canon EOS 30 Battery Door Replacement, Side Panel With Remote Control Socket: 步骤 7 中的图像 1,1
    • Remove two 6.5 mm black screws from the panel.
  8. Canon EOS 30 Battery Door Replacement: 步骤 8 中的图像 1,1
    • Remove the plastic remote control socket cap by pulling it straight out.
  9. Canon EOS 30 Battery Door Replacement: 步骤 9 中的图像 1,2 Canon EOS 30 Battery Door Replacement: 步骤 9 中的图像 2,2
    • Slide panel toward bottom of camera to remove.
  10. Canon EOS 30 Battery Door Replacement: 步骤 10 中的图像 1,1
    • Remove 4.8 silver screw on the Control Socket
  11. Canon EOS 30 Battery Door Replacement: 步骤 11 中的图像 1,2 Canon EOS 30 Battery Door Replacement: 步骤 11 中的图像 2,2
    • The Control Socket is now secure by 3 wires
    • Desolder connections to replace Remote Control Socket.
  12. Canon EOS 30 Battery Door Replacement, Top Panel: 步骤 12 中的图像 1,1
    • Slide the outer eyepiece upward to remove it.
  13. Canon EOS 30 Battery Door Replacement: 步骤 13 中的图像 1,1
    • Remove the two 4.75 mm black screws located on the top of the camera.
  14. Canon EOS 30 Battery Door Replacement: 步骤 14 中的图像 1,1
    • Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
  15. Canon EOS 30 Battery Door Replacement: 步骤 15 中的图像 1,2 Canon EOS 30 Battery Door Replacement: 步骤 15 中的图像 2,2
    • Slowly separate the top panel from the camera by pushing it upward.
    • Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
  16. Canon EOS 30 Battery Door Replacement, Grip: 步骤 16 中的图像 1,1
    • Remove the two 5.5 mm screws from front of camera.
  17. Canon EOS 30 Battery Door Replacement: 步骤 17 中的图像 1,1
    • Remove grip panel.
  18. Canon EOS 30 Battery Door Replacement, Battery Door: 步骤 18 中的图像 1,1
    • Remove one black screw from battery door on underside of grip.
  19. Canon EOS 30 Battery Door Replacement: 步骤 19 中的图像 1,1
    • Remove battery door.
结论
另外一个人完成了本指南。
Jackie
于04/17/11注册
236 声望
创作了3篇指南
团队
Cal Poly, Team 8-8, Regan Spring 2011 Cal Poly, Team 8-8, Regan Spring 2011 的会员
CPSU-REGAN-S11S8G8
5 名成员
创作了22篇指南
一条评论
I was able to complete this by going from step 9 to 15. Oddly, I only had one screw to remove in step 15 but the grip piece easily slid out without needing to remove the top of the camera.
Alan - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 19
总计 4,022
