跳转到主内容
Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement
你所需要的
  1. Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement, Flex-Cable Aperture - Aperture Flex: 步骤 1 中的图像 1,2 Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement, Flex-Cable Aperture - Aperture Flex: 步骤 1 中的图像 2,2
    • Here is the problem with this camera and the needed replacement part is shown.
  2. Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement, Remove bayonet lock: 步骤 2 中的图像 1,2 Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement, Remove bayonet lock: 步骤 2 中的图像 2,2
    • The bayonet lock is mounted with four little screws. Remove them and mark them (like all other screws) and put them aside
    • The black insert is a plastic part and fixed with four clips from below. The most upper ring can be lifted a little bit on the opposite side of the contacts. By doing that, you can remove one or two clips from below to push out the black insert carefully.
    • Be especially carefully not to put too much tension on the flex-cable which connects the contact-strip with the PCB below!
    • The contact-strip itself is fixed with two very tiny PH0-Phillips-screws from the outer side. Please remove both of them and put them aside
  3. Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement, Remove circuit board: 步骤 3 中的图像 1,2 Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement, Remove circuit board: 步骤 3 中的图像 2,2
    • Now, remove all flex cables from the the PCB very carefully. There are several different ways of connections.
    • remove the screw which holds the PCB in place and remove the board afterwards
  4. Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement, Removing assembly for scales: 步骤 4 中的图像 1,1
    • now disassemble the assembly with the scale for focal length and distance.
  5. Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement, Remove Focus assembly: 步骤 5 中的图像 1,1
    • now remove the assembly for the manual focus
  6. Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement, Disassemble the cage: 步骤 6 中的图像 1,1
    • now, it gets a little bit tricky: the rails of the "cage" are guided by little pins. These are individually sized and have to go exactly where they were before. So be careful and document everything in detail
  7. Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement: 步骤 7 中的图像 1,1
    • Dismantle aperture plate and IS assembly
  8. Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement: 步骤 8 中的图像 1,1
    • Unsolder old flex cable for the aperture plate
  9. Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement: 步骤 9 中的图像 1,2 Canon EF 24-105mm F4.0 L IS - Err01 Flex Cable Replacement: 步骤 9 中的图像 2,2
    • Resolder new cable for the aperture plate
结论
Um Ihr Gerät wieder zusammenzubauen, befolgen Sie diese Anweisungen in umgekehrter Reihenfolge.
6等其他人完成本指南。
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
jensloewe
于05/26/15注册
172 声望
撰写一个指南
2条评论
Stimmt nicht ganz. Die “Collars” mit dem Kreuz sind exzentrische und justieren die Optik. Einfach reinschrauben wo´s mal war is nicht! Danach kann man das Teil in die Tonne kloppen oder dann für teures Geld zu Canon schicken.
Bitte unbedingt alle Bastelwütigen genau auf das hinweisen.
Was kann man tun? In der Regel ist immer einer von den dreien zentrisch; der kann bedenkenlos am gleichen Platz montiert werden. Vom Rest von jeder Seite genug Fotos machen und Markierunen anbringen WO genau das Kreuz war. Da geht´s eigentlich um´s Hunderstel. Wenn´s danach für den Hausgebrauch bei f8 ist… Also Zeit lassen, Linsengruppen nicht verdrehen usw.
Thomas Loebl - 回复
Jupp, da muss auf jeden Fall drauf hingewiesen werden. Wenn die exzentrischen Pins vorne an der Blenden/IS Einheit beim rauspulen auch noch verbogen werden, wars das ohnehin. So, wie in der Anleitung beschrieben, ist das leider eine Reparatur für die Tonne.
Patch -
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 58
过去 30 天: 149
总计 9,035
