跳转到主内容
Canary CAN100USBK Ethernet PCB Board Replacement
你所需要的
  1. Canary CAN100USBK Ethernet PCB Board Replacement, Bottom Casing: 步骤 1 中的图像 1,2 Canary CAN100USBK Ethernet PCB Board Replacement, Bottom Casing: 步骤 1 中的图像 2,2
    • Grip the rubber ring with your fingers and pull up.
    • Rotate the Canary as you pull out one tab at a time.
  2. Canary CAN100USBK Ethernet PCB Board Replacement: 步骤 2 中的图像 1,1
    • Use your Phillips #0 screwdriver to remove the four 6mm screws.
  3. Canary CAN100USBK Ethernet PCB Board Replacement: 步骤 3 中的图像 1,3 Canary CAN100USBK Ethernet PCB Board Replacement: 步骤 3 中的图像 2,3 Canary CAN100USBK Ethernet PCB Board Replacement: 步骤 3 中的图像 3,3
    • Use the flat end of the spudger to carefully pry off the bottom casing.
    • Alternate pushing up on the left and right sides until the clips holding the case in are visible.
  4. Canary CAN100USBK Ethernet PCB Board Replacement: 步骤 4 中的图像 1,2 Canary CAN100USBK Ethernet PCB Board Replacement: 步骤 4 中的图像 2,2
    • Do not yank the bottom off or you may damage the ribbon cable or the ZIF connector.
    • Carefully remove the bottom casing by gripping it on both sides and pulling straight up.
  5. Canary CAN100USBK Ethernet PCB Board Replacement: 步骤 5 中的图像 1,2 Canary CAN100USBK Ethernet PCB Board Replacement: 步骤 5 中的图像 2,2
    • Use the pointed end of the spudger to flip up the small retaining flap on the ZIF (zero insertion force) connector.
    • Pull the ribbon cable out towards the device.
  6. Canary CAN100USBK Ethernet PCB Board Replacement, Ethernet PCB Board: 步骤 6 中的图像 1,1
    • Use your Phillips #0 screwdriver to remove the three 5mm screws.
  7. Canary CAN100USBK Ethernet PCB Board Replacement: 步骤 7 中的图像 1,2 Canary CAN100USBK Ethernet PCB Board Replacement: 步骤 7 中的图像 2,2
    • Place the flat end of the spudger underneath the Ethernet PCB board and slowly pry up until it's loose.
  8. Canary CAN100USBK Ethernet PCB Board Replacement: 步骤 8 中的图像 1,1
    • Carefully pull the Ethernet PCB board away from the board that sits underneath.
结论
Tommy Nguyen
于02/28/17注册
597 声望
创作了5篇指南
团队
USF Tampa, Team S1-G2, Nance Spring 2017 USF Tampa, Team S1-G2, Nance Spring 2017 的会员
USFT-NANCE-S17S1G2
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 1,079
