简介
The audio jack is not used for audio, but for streaming setup data from your phone to the Canary, so it is very important to replace if damaged.
Once you remove the bottom casing and Ethernet PCB board, the audio and USB PCB board becomes accessible. Remember to pull on the power connector itself and not the wires to avoid damage.
If either the audio jack or USB type C connector are damaged, this guide will show you how to replace the board.
A Phillips #0 screwdriver can be used for both screws.
你所需要的
Grip the rubber ring with your fingers and pull up.
Rotate the Canary as you pull out one tab at a time.
Use the pointed end of the spudger to flip up the small retaining flap on the ZIF (zero insertion force) connector.
Pull the ribbon cable out towards the device.
Using your fingernails, wiggle the power connector back and forth until it becomes loose.
Pull the power connector straight out of the socket.
3等其他人完成本指南。
2条评论
Hello great tutorial I have a problem with the usb on mine.
Where did you buy the PCB from?
