跳转到主内容
Canary CAN100USBK Audio and USB PCB Board Replacement
你所需要的
  1. Canary CAN100USBK Audio and USB PCB Board Replacement, Bottom Casing: 步骤 1 中的图像 1,2 Canary CAN100USBK Audio and USB PCB Board Replacement, Bottom Casing: 步骤 1 中的图像 2,2
    • Grip the rubber ring with your fingers and pull up.
    • Rotate the Canary as you pull out one tab at a time.
  2. Canary CAN100USBK Audio and USB PCB Board Replacement: 步骤 2 中的图像 1,1
    • Use your Phillips #0 screwdriver to remove the four 6mm screws.
  3. Canary CAN100USBK Audio and USB PCB Board Replacement: 步骤 3 中的图像 1,3 Canary CAN100USBK Audio and USB PCB Board Replacement: 步骤 3 中的图像 2,3 Canary CAN100USBK Audio and USB PCB Board Replacement: 步骤 3 中的图像 3,3
    • Use the flat end of the spudger to carefully pry off the bottom casing.
    • Alternate pushing up on the left and right sides until the clips holding the case in are visible.
  4. Canary CAN100USBK Audio and USB PCB Board Replacement: 步骤 4 中的图像 1,2 Canary CAN100USBK Audio and USB PCB Board Replacement: 步骤 4 中的图像 2,2
    • Do not yank the bottom off or you may damage the ribbon cable or the ZIF connector.
    • Carefully remove the bottom casing by gripping it on both sides and pulling straight up.
  5. Canary CAN100USBK Audio and USB PCB Board Replacement: 步骤 5 中的图像 1,2 Canary CAN100USBK Audio and USB PCB Board Replacement: 步骤 5 中的图像 2,2
    • Use the pointed end of the spudger to flip up the small retaining flap on the ZIF (zero insertion force) connector.
    • Pull the ribbon cable out towards the device.
  6. Canary CAN100USBK Audio and USB PCB Board Replacement, Ethernet PCB Board: 步骤 6 中的图像 1,1
    • Use your Phillips #0 screwdriver to remove the three 5mm screws.
  7. Canary CAN100USBK Audio and USB PCB Board Replacement: 步骤 7 中的图像 1,2 Canary CAN100USBK Audio and USB PCB Board Replacement: 步骤 7 中的图像 2,2
    • Place the flat end of the spudger underneath the Ethernet PCB board and slowly pry up until it's loose.
  8. Canary CAN100USBK Audio and USB PCB Board Replacement: 步骤 8 中的图像 1,1
    • Carefully pull the Ethernet PCB board away from the board that sits underneath.
  9. Canary CAN100USBK Audio and USB PCB Board Replacement, Audio and USB PCB Board: 步骤 9 中的图像 1,1
    • Using your fingernails, wiggle the power connector back and forth until it becomes loose.
    • Pull the power connector straight out of the socket.
    • Pull only on the power connector and not the wires themselves to prevent damage.
  10. Canary CAN100USBK Audio and USB PCB Board Replacement: 步骤 10 中的图像 1,3 Canary CAN100USBK Audio and USB PCB Board Replacement: 步骤 10 中的图像 2,3 Canary CAN100USBK Audio and USB PCB Board Replacement: 步骤 10 中的图像 3,3
    • Use the spudger to pry up the retaining flap of the ZIF connector.
    • Disconnect the ribbon cable.
  11. Canary CAN100USBK Audio and USB PCB Board Replacement: 步骤 11 中的图像 1,1
    • Remove the two Phillips #0 5mm screws.
  12. Canary CAN100USBK Audio and USB PCB Board Replacement: 步骤 12 中的图像 1,2 Canary CAN100USBK Audio and USB PCB Board Replacement: 步骤 12 中的图像 2,2
    • Pull the board away from the bottom casing by lifting the end closest to the chimney up.
结论
3等其他人完成本指南。
Kristopher Gates
于02/28/17注册
399 声望
创作了3篇指南
团队
USF Tampa, Team S1-G2, Nance Spring 2017 USF Tampa, Team S1-G2, Nance Spring 2017 的会员
USFT-NANCE-S17S1G2
4 名成员
创作了16篇指南
2指南评论
Hello great tutorial I have a problem with the usb on mine.
Where did you buy the PCB from?
craig perrin - 回复
nice guide, need to buy the ep-cnc01bb-02 board which has the micro usb on it as mine is worn out... any ideas?
Billy - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 1,088
