跳转到主内容
CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement
你所需要的
  1. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement, Power Cord: 步骤 1 中的图像 1,1
    • Use a metal spudger to pry off the silver, shiny trim.
  2. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: 步骤 2 中的图像 1,1
    • Remove inner black housing of the CHI Spin N Curl using the metal spudger to pop it out.
  3. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: 步骤 3 中的图像 1,2 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: 步骤 3 中的图像 2,2
    • Use a 2 mm flathead to remove the two screws.
  4. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: 步骤 4 中的图像 1,2 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: 步骤 4 中的图像 2,2
    • Use a metal spudger to pry open the seams of the device.
  5. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: 步骤 5 中的图像 1,3 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: 步骤 5 中的图像 2,3 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: 步骤 5 中的图像 3,3
    • Toward the bottom of the device, grab the swivel power cord.
    • Gently pull the power cord to detach it from the CHI Spin N Curl
    • Replace the faulty cord when the original cord has been removed.
  6. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement, Temperature Control Switch: 步骤 6 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the screws on both sides of the temperature control switch.
    • Pop out the control switch.
结论
Annalise White
于10/26/22注册
530 声望
创作了5篇指南
团队
UMass Dartmouth, Team 2-7, Petersen Fall 2022 UMass Dartmouth, Team 2-7, Petersen Fall 2022 的会员
UMASSD-PETERSEN-F22S2G7
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 10
总计 223
