跳转到主内容
Brother CS6000i Sewing Light Replacement
你所需要的
  1. Brother CS6000i Sewing Light Replacement, Body: 步骤 1 中的图像 1,2 Brother CS6000i Sewing Light Replacement, Body: 步骤 1 中的图像 2,2
    • Remove the five 20 mm Phillips #2 screws on the back of the device.
    • Remove the single 28 mm Phillips #2 screw on the back of the device.
    • Remove the single 23 mm Phillips #2 screw on the back of the device.
  2. Brother CS6000i Sewing Light Replacement: 步骤 2 中的图像 1,2 Brother CS6000i Sewing Light Replacement: 步骤 2 中的图像 2,2
    • Pull the white cover off.
  3. Brother CS6000i Sewing Light Replacement: 步骤 3 中的图像 1,2 Brother CS6000i Sewing Light Replacement: 步骤 3 中的图像 2,2
    • Remove the final screw, a 11 mm Phillips #2.
    • After removing all eight screws, you will have five 2 mm screws, one 28 mm screw, one 23 mm screw, and one 11 mm screw, all of which are Phillips #2.
  4. Brother CS6000i Sewing Light Replacement: 步骤 4 中的图像 1,3 Brother CS6000i Sewing Light Replacement: 步骤 4 中的图像 2,3 Brother CS6000i Sewing Light Replacement: 步骤 4 中的图像 3,3
    • Slightly pull apart the two halves of the machine, taking care not to strain the attached cables.
    • Unhook the white wires that are connected to the motherboard.
    • Fully separate the two halves.
  5. Brother CS6000i Sewing Light Replacement, Sewing Light: 步骤 5 中的图像 1,1
    • Use a Phillips #2 screwdriver to remove the single 16 mm Phillips #2 screw.
    • Remove the metal plate.
  6. Brother CS6000i Sewing Light Replacement: 步骤 6 中的图像 1,1
    • Use a Phillips #2 screwdriver to remove the two 16 mm Phillips #2 screws.
    • Remove the metal plate underneath screws once screws are removed.
  7. Brother CS6000i Sewing Light Replacement: 步骤 7 中的图像 1,1
    • Use a standoff tip to remove the 10 mm Phillips #2 screw directly next to the lightbulb.
  8. Brother CS6000i Sewing Light Replacement: 步骤 8 中的图像 1,1
    • Disconnect the light connector from the PCB.
  9. Brother CS6000i Sewing Light Replacement: 步骤 9 中的图像 1,1
    • Remove the light.
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Aidan Lear
于10/31/24注册
130 声望
撰写一个指南
团队
Cuesta, Team 20-1, Krynen Fall 2024 Cuesta, Team 20-1, Krynen Fall 2024 的会员
CUESTA-KRYNEN-F24S20G1
5 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 24
总计 215
