简介
The battery is essential and can wear out or stop working over time. This guide will show you how to properly remove it.
Tech Tip: this Replacement guide will require the use of a soldering iron to remove solders, so check out the soldering guide if you're unfamiliar with the process.
你所需要的
Remove three 8mm screws from the left side of the device.
Remove four 8mm screws from the right side of the device.
Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver.
Flip the motherboard over.
Desolder the two solder joints and remove the melted solder.
在这个步骤中使用的工具:Desoldering Pump$3.99
Apply the desoldering pump to remove the melted part from the motherboard (press the button to release it).
Pull the battery from the motherboard.
