跳转到主内容
Braun Shaver Model 7680 Battery Replacement
你所需要的
  1. Braun Shaver Model 7680 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Soldering is required to install this battery one or two batteries may be required verify how many you need before you order
  2. Braun Shaver Model 7680 Battery Replacement, Remove bottom cover: 步骤 2 中的图像 1,2 Braun Shaver Model 7680 Battery Replacement, Remove bottom cover: 步骤 2 中的图像 2,2
    • First pry the left side of the cover off, then pry the right side of the cover off before removing. Trying to pry the cover off from only one side will result in breaking the plastic tabs.
  3. Braun Shaver Model 7680 Battery Replacement, Remove side covers: 步骤 3 中的图像 1,1
    • Pull the side covers off from the bottom, they hinge from the top and will come off freely once you rotate them up and away from the body starting at the bottom.
  4. Braun Shaver Model 7680 Battery Replacement, Remove screws on back: 步骤 4 中的图像 1,2 Braun Shaver Model 7680 Battery Replacement, Remove screws on back: 步骤 4 中的图像 2,2
    • You will need a T9 hex screw driver.
    • R17 AA NiMh Battery With Pin Tabs 1650 Mah 1.2V Battery Measures .559" x 1.97", 14.2mm x 50mm
    • Replacing the batteries will not always repair the shaver, the circuit board may be bad, if the indicator lights on the circuit board do not light up when plugged in the circuit board is most likely bad, you should replace the entire circuit board and battery assembly.
结论
19等其他人完成本指南。
mayer
于01/04/10注册
685,379 声望
创作了12篇指南
团队
MacHale Enterprises MacHale Enterprises 的会员
Business
1 名成员
创作了18篇指南
8条评论
Great tutorial. It was all I needed, since I wasn't sure how to get the case open. Thanks!
mikebailey - 回复
Thanks for the tutorial! Mine had intermittent problem with the on/off switch and I was googling how to open the case. Easy and simple, bets razor I’ve had and not willing to change :D
Tero Kortetmäki - 回复
Thanks for the tutorial… but it is a T8 Torx at least in the Model 7570. I just had to take out the recharchable batteries to get mine working properly again.
A Krueger - 回复
Danke für die übersichtliche Anleitung, hat mir gut geholfen. Die wichtige Frage ist immer:
Wie geht ‘s Gehäuse auf. ?
Garofalo - 回复
Thanks for the guide! Without knowing how to open the case, replacing the battery would have been a lost cause. In my case the batteries were tired. After replacing and recharging them the razor sounds young again and full of pep.
Stephen Spratley - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 22
过去 30 天: 113
总计 21,606
