跳转到主内容
Bose QuietComfort 25 Speaker Replacement
你所需要的
  1. Bose QuietComfort 25 Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Begin repair by removing the ear cushions.
    • The cushion is held on by a few small plastic clips. Pry carefully with plastic opening tool or fingernails.
  2. Bose QuietComfort 25 Speaker Replacement: 步骤 2 中的图像 1,1
    • Next, remove the soft lining behind the cushion. This is held on with adhesive and is easily removed by hand.
  3. Bose QuietComfort 25 Speaker Replacement: 步骤 3 中的图像 1,3 Bose QuietComfort 25 Speaker Replacement: 步骤 3 中的图像 2,3 Bose QuietComfort 25 Speaker Replacement: 步骤 3 中的图像 3,3
    • Once the soft lining is removed from behind the ear cushion, two screws (4.80mm) will be exposed.
    • Carefully remove these screws with a precision screwdriver (PH00) and put aside.
  4. Bose QuietComfort 25 Speaker Replacement: 步骤 4 中的图像 1,1
    • Flip the earphones back over and carefully pry around the outside cover of the earpiece.
    • Try a plastic opening tool before moving on to harder metal tools.
    • This cover will come loose with moderate pressure.
  5. Bose QuietComfort 25 Speaker Replacement: 步骤 5 中的图像 1,2 Bose QuietComfort 25 Speaker Replacement: 步骤 5 中的图像 2,2
    • Once the inside of the headphone is exposed, use screw driver (PH00) to remove the two 4mm screws on the black speaker cover.
  6. Bose QuietComfort 25 Speaker Replacement: 步骤 6 中的图像 1,1
    • Use a heat gun to carefully loosen the glue on the speaker cover.
  7. Bose QuietComfort 25 Speaker Replacement: 步骤 7 中的图像 1,1
    • Use metal tool to break the seal of the glue and pry the cover off.
    • Be careful during this step as the speaker might still be attached to the cover.
  8. Bose QuietComfort 25 Speaker Replacement: 步骤 8 中的图像 1,2 Bose QuietComfort 25 Speaker Replacement: 步骤 8 中的图像 2,2
    • Remove all soldered connections that are connecting the existing speaker to the headphone. For help with this step see this guide on 如何焊接和拆焊
    • The existing speaker should now be free to remove and replace.
结论
12等其他人完成本指南。
Bryton Wise
于03/26/18注册
508 声望
撰写一个指南
团队
IUPUI, Team S2-G3, Harley Spring 2018 IUPUI, Team S2-G3, Harley Spring 2018 的会员
IUPUI-HARLEY-S18S2G3
3 名成员
创作了6篇指南
17条评论
Hi, where did you get your replacement speaker from, (there are so many on eBay, I have no idea which ones are good quality)?
Also, do you recommend replacing both speakers at the same time, or is it ok to replace just the broken one?
Thanks
Flapdoodle - 回复
I repaired a headset of this type after this instruction. That went without problems. It would be a speaker defect. However, one pair cost specifically for this headset in the "Bay" only € 1.29, or a speaker just over 60 cents. I did not notice a difference in the sound quality !!! You can buy the speaker also "original" from Bose for about 22 €, but think that comes from the bay! So much for Bose!
Translation in german language
Ich habe nach der Anweisung einen Kopfhörer dieser Bauart repariert. Das ging ohne Probleme. Es wr ein Lautsprecher defekt. Allerdings kostete 1 Paar speziell für diesen Kopfhörer in der “Bucht” nur 1,29€, bzw. ein Lautsprecher nur etwas über 60 Cent. Ich habe keinen Unterschied in der Klangqualität wahrgenommen!!! Man kann den Lautsprecher auch “original “von Bose für ca. 22€ kaufen, denke aber, dass der auch aus der Bucht kommt! Soviel zu Bose!
G. B. - 回复
Does anyone know where one could get a replacement for the internal speaker cover, mines kind of melted. is there a way that anyone has a 3D model so I can get it printed ?
thanks
Haku Nippon - 回复
I am having the same problem.
Tomas C -
Do you need to apply fresh glue to reseal the speaker cover, and if so, what is the best glue to use?
Eaton Hubbard - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 50
过去 30 天: 171
总计 22,669
