跳转到主内容
Bose Quiet Comfort 35 II Audio Jack Connector Replacement
你所需要的
  1. Bose Quiet Comfort 35 II Audio Jack Connector Replacement, Audio Jack Cable Connector: 步骤 1 中的图像 1,1
    • Take off ear cushion pad using the plastic opening tool. Pry until you notice the seam of the ear cushion separates from the plastic tabs.
  2. Bose Quiet Comfort 35 II Audio Jack Connector Replacement: 步骤 2 中的图像 1,3 Bose Quiet Comfort 35 II Audio Jack Connector Replacement: 步骤 2 中的图像 2,3 Bose Quiet Comfort 35 II Audio Jack Connector Replacement: 步骤 2 中的图像 3,3
    • Take off the ear cover by peeling off the glue with hands.
  3. Bose Quiet Comfort 35 II Audio Jack Connector Replacement: 步骤 3 中的图像 1,2 Bose Quiet Comfort 35 II Audio Jack Connector Replacement: 步骤 3 中的图像 2,2
    • Remove the two 7-millimeter silver screws from the inside by using the Phillips #000 screwdriver to disconnect the back cover.
  4. Bose Quiet Comfort 35 II Audio Jack Connector Replacement: 步骤 4 中的图像 1,2 Bose Quiet Comfort 35 II Audio Jack Connector Replacement: 步骤 4 中的图像 2,2
    • Remove the two 5-millimeter silver screws attaching the earphones to the headband using the Phillips #000 screwdriver.
  5. Bose Quiet Comfort 35 II Audio Jack Connector Replacement: 步骤 5 中的图像 1,2 Bose Quiet Comfort 35 II Audio Jack Connector Replacement: 步骤 5 中的图像 2,2
    • Detach the earpiece form the band using the flat part of the metal spudger.
    • Slide the joint at the end of the headphone band out to release ear piece.
  6. Bose Quiet Comfort 35 II Audio Jack Connector Replacement: 步骤 6 中的图像 1,2 Bose Quiet Comfort 35 II Audio Jack Connector Replacement: 步骤 6 中的图像 2,2
    • Detach the silver cover on the outside of the headset using the spudger.
    • Pry until you hear a distinct pop; this indicates the cover has separated from its base.
  7. Bose Quiet Comfort 35 II Audio Jack Connector Replacement: 步骤 7 中的图像 1,2 Bose Quiet Comfort 35 II Audio Jack Connector Replacement: 步骤 7 中的图像 2,2
    • Solder off the ribbon cable from the driver near the cable connector port to detach it.
  8. Bose Quiet Comfort 35 II Audio Jack Connector Replacement: 步骤 8 中的图像 1,2 Bose Quiet Comfort 35 II Audio Jack Connector Replacement: 步骤 8 中的图像 2,2
    • Replace the cable connector with spare driver/audio jack combo.
    • Optional: desolder the five audio jack posts seen here, and replace individual audio jack.
结论
kssexton
于11/08/23注册
463 声望
创作了3篇指南
团队
IUPUI, Team 1-2, Harley Fall 2023 IUPUI, Team 1-2, Harley Fall 2023 的会员
IUPUI-HARLEY-F23S1G2
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 55
总计 443
