跳转到主内容
Blu Grand M2 Display Replacement
你所需要的
  1. Blu Grand M2 Display Replacement, Display: 步骤 1 中的图像 1,2 Blu Grand M2 Display Replacement, Display: 步骤 1 中的图像 2,2
    • Before beginning the guide, be sure that this replacement guide addresses your specific problem.
    • Locate the two Torx screws at the bottom of the phone and remove them.
  2. Blu Grand M2 Display Replacement: 步骤 2 中的图像 1,1
    • Use the pry tool to wedge between the phone's frame and the back plate.
    • Carefully remove the back plate using the suction tool.
    • Be careful not to damage the phone display and/or the inside components while using the pry tool and the suction tool.
  3. Blu Grand M2 Display Replacement: 步骤 3 中的图像 1,3 Blu Grand M2 Display Replacement: 步骤 3 中的图像 2,3 Blu Grand M2 Display Replacement: 步骤 3 中的图像 3,3
    • Once the back panel is removed, locate the connector of the display shown in figure 1 on the motherboard side.
    • There will be an orange sticker above the previously mentioned connector. You can gently lift the connector up to release it.
    • Disconnect the two remaining connectors shown in figure 3.
  4. Blu Grand M2 Display Replacement: 步骤 4 中的图像 1,2 Blu Grand M2 Display Replacement: 步骤 4 中的图像 2,2
    • After removing the connectors, locate the six Phillips screws on the motherboard side and remove them.
    • After removing the six Phillips screws, remove the motherboard piece.
  5. Blu Grand M2 Display Replacement: 步骤 5 中的图像 1,1
    • Once you have removed the motherboard piece, flip the phone so the screen is facing up and begin using the iOpener.
    • Heat up the iOpener from the iFixit kit for 30 seconds in a microwave and apply it on top of the screen to loosen the phone's adhesive.
    • The iOpener can be hot once it is microwaved. Make sure to wear gloves and other safety equipment to prevent any burns.
  6. Blu Grand M2 Display Replacement: 步骤 6 中的图像 1,3 Blu Grand M2 Display Replacement: 步骤 6 中的图像 2,3 Blu Grand M2 Display Replacement: 步骤 6 中的图像 3,3
    • Using the suction tool, slowly pull out the display screen shown in figure 1.
    • Use the pry tool to completely detach the display screen from the phone.
    • When the display is removed, attach your new screen.
    • After applying the new screen, use the steps in reverse order to reassemble the phone.
结论
Christopher
于09/10/18注册
192 声望
撰写一个指南
团队
Gateway, Team S1-G3, Luster Fall 2018 Gateway, Team S1-G3, Luster Fall 2018 的会员
GCC-LUSTER-F18S1G3
4 名成员
创作了4篇指南
1指南评论
What type of torx screwdriver did you use?
npyles86 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 30
总计 1,956
